1999 polaris scrambler 500 4x4?
Old 04-02-2009, 11:23 AM
hondafl350's Avatar
Default 1999 polaris scrambler 500 4x4?
Hi i have a 1999 polars scrambler 500 4x4 and i was wondering if i could use different weights in the drive clutch? the original ones are WHF 10 weights. is it possible to put WH 16 in without causing any damage to the engine? if u think it would be safe what changes might i be expecting? thank you very much for your help.
Old 04-02-2009, 04:30 PM
ftwflh's Avatar
stock weights are 10WH (46 gram) on 500s.
If you have an understanding of CVT clutching you can change to any combo springs and weights you want.But if you go too light or heavy of weights you stand a chance of blowing an engine due to exsessive RPM (lighter)or lose topend speed with too heavy.
Get everything dialed in and you can have a monster
Old 04-03-2009, 10:28 AM
hondafl350's Avatar
Default thanks
thank you very much for your help I guess my new question is can i use the 16 weight with stock springs and everything on my ATV?
Old 04-03-2009, 04:45 PM
ftwflh's Avatar
I wouldnt you need the 10WH on a stock 500 Scrambler
scram5050
07-27-2015 01:23 PM
maxjung
07-14-2015 12:29 PM
maxjung
07-14-2015 12:11 PM
maxjung
07-14-2015 03:10 AM
maxjung
07-13-2015 05:11 PM
Quick Reply: 1999 polaris scrambler 500 4x4?
