Bypass reverse over ride switch?
Old 04-20-2009, 03:31 PM
wickedzr's Avatar
Default Bypass reverse over ride switch?
I have a 2001 400 Scrambler and want to bypass the
reverse over ride switch. Can someone help.
Also what about putting in a manual switch
for the cooling fan? Is that a good idea?
Will doing this be the same on a 98 400 Sport?
Thanks,
van
Old 04-20-2009, 03:59 PM
The original Firehawk's Avatar
Check out:
ATV parts, ATV tires, Quadovator ATV Accessories for reverse over-ride.
Just installed the kit on mine. Easy and works great!
Old 04-20-2009, 08:37 PM
ftwflh's Avatar
Find the rev box (the one with 3 wires and unplug the black wire
Old 04-20-2009, 08:49 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
Just remember if any other riders ride the Quad!!!
Kids and or children will have it in reverse and there will be no restriction on the amount of throttle they can use,......Caper......
Great if it is just you using the Quad.............
Old 04-22-2009, 05:15 PM
PUSHNF8's Avatar
Would that same wire work on the 04 scramblers? Where would the box be located? Just unplug it?
Old 04-22-2009, 06:34 PM
ftwflh's Avatar
The 04s are dif.I havent figured out how to do those yet
Old 04-22-2009, 09:41 PM
Outback31's Avatar
Has ridden Rockhouse and Bearwallow trails.
Default 07 800
Can you do it to this model without buying an aftermarket kit from quadovator?
Old 04-23-2009, 06:01 AM
ftwflh's Avatar
The older models you just unplug a wire but the newer ones are made dif.
Old 04-23-2009, 06:19 AM
stendori's Avatar
I'm watching you!
if its like the newer sportsman set up then you have to put 2 wires together on a switch, or maybe even just putting the wires together will do it. just a guess as i havent seen a scrambler set up.
Old 04-23-2009, 07:06 AM
Miaugi's Avatar
I'd like to do this on my wife's '02 SP 400. Mostly because she always forgets to push it in and then gives me a WTF look when she can't back out of where she's gotten into. LOL
Can someone please let me know where is this box so I can disconnect that black wire?
Quick Reply: Bypass reverse over ride switch?
