1999 KODIAK U joint replacement
Old 05-18-2009, 06:43 PM
frede zorn's Avatar
Default 1999 KODIAK U joint replacement
1999 yamaha kodiak needs front u joints. can anyone tell me how to remove the front drive shaft???? Thanks
Old 08-22-2009, 10:17 PM
k.hughes425's Avatar
There are ring clips on the top of each end remove them with a ring clip puller and beat them apart with a hammer!
Old 09-01-2009, 10:44 PM
jn452's Avatar
Default what about the u-joint on the transfer case?
I am having some what of the same problem with my 93-95 (can't remember exactly) Kodia 400. Some thing in the front end was squaking so i got all m=nem bearings seals and u-joints for the front drive train. Every thing was going well till i got to the u-joint for the drive shaft that is attaced to the transfer case. How in the wolrd do you remove and replace that one. And please do not tell me i have to pull the transfer case. everything else has been easy. Please help
Old 09-02-2009, 06:09 PM
Default inner u joint replacment
If you remove the outer part of the axle from the hub, by removing the axle nut, tierod end and lower or upper ball joint, then and pull the axle away from the diff. it will pop right out to make it easy to get to, It may take a few good tugs by a healthy man but it will pop right out then you can get the u joint off easy!
toonces
07-28-2015 01:58 PM
kdg723
07-25-2015 01:20 PM
Peter_
07-18-2015 07:06 AM
musselmark
07-17-2015 02:40 PM
RedRancher
07-10-2015 06:36 PM
Quick Reply: 1999 KODIAK U joint replacement
