Help....1986 fourtrax 250 hub
Old 06-06-2009, 08:27 PM
jayb1982's Avatar
Default Help....1986 fourtrax 250 hub
I had a 1986 honda fourtrax 250 sittin in my back yard got it running mint but ran in to a little problem. front bearings are shoton left side. so i was wondering how u remove the cover over the brakes (hub). I took the axle nut. but the hub wont slip, just wondering if anyone can help
thanks
Old 06-08-2009, 05:38 AM
HondaMechanic's Avatar
Old 06-09-2009, 09:25 AM
jayb1982's Avatar
thanks the drum puller worked awsome, I was wondering if you knew a easy way how to remove the 2 bearing and collar from the hub
Old 06-09-2009, 07:23 PM
wonderboy563's Avatar
scince you are replacing the bearing what i do on cars is to use a cut off wheel to cut about half way threw the race that is stuck then take a chisel and give it a good wack in the groove that you cut. it should crack then you can slide it rite off. make sure to wear saftey glasses they like to chip.
wendal
10-31-2017 03:31 AM
wendal
09-15-2015 01:50 PM
wendal
09-15-2015 01:48 PM
Steeldon
09-08-2015 10:51 AM
ScopeZ_
07-28-2015 01:44 AM
Quick Reply: Help....1986 fourtrax 250 hub
