Clunk, when shifting into forward or reverse on my Trail Boss 330
I just picked up a 2004 trial Boss 330, with low hours. Would it be considered fairly normal to hear a click/clunk when shifting into forward or into reverse?
I hold the brake while shifting and the idle seems to be low enough. I checked the trans fluid and it's clean and up to proper level.
No it doesn't jerk, I don't have to give it a hard push or pull either, just seemed kinda loud sometimes.
ftwflh, thanks, I'll check that out.
Off topic here....We had an 02 Trail Boss... if you wanna add a little zip to it, drop a tooth in the front sprocket. It'll take away a little of the top speed of the machine, but it doesn't really have all that much top speed to lose. It's a great little machine tho, and for us, it was bulletproof.
