Yamaha Side by Sides Talk about the durable Yamaha Sport and Utility
Carb Problem - Has anyone had this problem
Old 06-14-2009, 09:17 PM
RaptorOwner's Avatar
Default Carb Problem - Has anyone had this problem
Top of the carb that holds the needle, I took it off and there was a hole in the side of the rubber diaphram that is matches up with the opening for the throttle, is there something or some way that the vacuum suction from there that would pull the side wall of the rubber diaphram into that? I have found this problem after my rhino was running crappy. 2006 660 is the model. Help....
Old 08-17-2009, 08:07 PM
wheily's Avatar
there should be no oles in that diaphram they dont run to great like that not sure what could have caused the hole
Old 08-21-2009, 11:21 PM
atv parts plus's Avatar
change diapharm should be ok. is it not opening up full throtle?
Ty Speece
07-02-2015 04:59 PM
wildbill59
06-09-2015 02:28 AM
generalpops
06-05-2015 08:23 PM
garyt1975
06-05-2015 08:53 AM
generalpops
06-03-2015 08:25 PM
Quick Reply: Carb Problem - Has anyone had this problem
