What Oil should I use in the Transmission?
Old 06-25-2009, 02:07 AM
Beau49's Avatar
Default What Oil should I use in the Transmission?
I noticed tonight that the oil in the Transmission of my 1996 explorer 300 2-cycle is looking pretty bad. I have been trying to catch up with the Maintenance on it since I bought it last fall.
I don't think I am going to have time to go to our Polaris dealer this week since he is about 1 1/2 hours away. I would like to change it before Friday night as my son and a friend of his are taking the 4 Wheelers out for a day of riding leaving on Saturday morning.
We do have a Artic-Cat and a Honda dealer in town so if I had to I could get oil from them if I just new what to get. I also could go to one of the Auto Parts stores and get what I need.
I looked at the owners manual on line for a 1998 300 explorer and the only thing it listed is Polaris Premium Synthetic Gearcase Lubricant (PN2871478 - 12 oz. bottle.
So if someone would be kind enough to tell me what Kind of Oil I need from either the Artic-Cat or Honda dealer or the Auto parts store that would be great.
I did not know to much about ATV'S when I bought this one but I guess it was not in as good as shape as I thought it was at the time. Now when I buy my next one I think I know what to look for.
I guess you could say I am learning the hard way about ATV's
Thanks in Advance for any information on Transmisson oil anyone can give me
Old 06-25-2009, 05:38 AM
hoytultratec's Avatar
my 96 manual says 10W 30, I believe when i changed it i used mobil 1 10w30. (synthetic) I think!
Old 06-25-2009, 05:57 AM
ftwflh's Avatar
Would not recomend anny type of motor oil in the tranny.This is more of a chain case.If you cant get the Polaris AGL find another chaincase lube such as Amsoil.It need to be thin to keep the chain cool and lubed.
Old 06-25-2009, 08:50 AM
HARLEY_OWNER's Avatar
does your dip stick have the metal or plastic.. tward the back or in the middle?
on my 99 its a yellow plastic dip stick.. that is like ftw said gear oil.. i run 80 -90 in mine.. but if you have the metal dip stick then i cant remember what i ran in my 94.. i would call someone that works on them.. not a dealer..
Old 06-25-2009, 04:17 PM
this is right from my manual.
Recommended lubes and fluids.
engine
2 stroke models.
transmission oil
type.........motor oil,API grade SG or SH
viscosity....10W-30.
counterbalance fluid (dont think they have them on the 300?)
SAE10W-30 engine oil.
??????????? I just use what the manual says (right or wrong) ?????
Old 06-25-2009, 04:36 PM
96 models were the first year to use AGl,before 96, gear cases used a non synthetic nasty looking graphite type trans fluid. Looked nasty going in and nastier at draining! You can use AGL or any lube suitable for CHAIN CASE transmissions! Think I still have 2 1/2 gallon jug of the stuff somewhere!
Old 06-25-2009, 04:38 PM
ftwflh's Avatar
Thats what I was trying to say.Hey I have a few qts of the old mineral spirts chain lube around that I run in the older machines I service.
Jeff Roper
02-01-2022 11:48 AM
r1pilot83
Utility ATVs
15
11-25-2019 11:39 PM
shimanok2
01-29-2016 07:37 PM
r1pilot83
09-27-2015 07:38 PM
WilliamBos
09-22-2015 04:07 PM
Quick Reply: What Oil should I use in the Transmission?
