Oil injection bypass
Old 06-29-2009, 07:56 AM
skram's Avatar
Default Oil injection bypass
I want to bypass my oil injection what do I mix my xplorer 300 at ? I also gave her alittle body mod...I put new pro taper bars on and removed the dummy lights, after doing so my headlights brake lights and fan didn't work. I wired the fan direct on a toggle, Why would those dummy lights effect everything? do they have to be there to complete the circuits? I went riding yesterday and she started running rough, She finally quit thats when I realized the fan wasn't working. I let cool and got her home, wired the fan, went for another ride...quit again, seemed to be a fuel issue dirt in tank wasn't getting fuel so I put it reserve got her home...cleaned the tank put fresh gas in went around the block and she quit again half way can't get her started???????????? what now???
Old 06-29-2009, 03:45 PM
Check compression,if ok(around 100 psi minimum) then check carb for trash in the jets.If runs and quits could be loosing compression when hot,may be time for a little piston /cylinder work????
Dont know how you wired things up,but sounds like a ground problem OR you are triggering the thermal fuse. Oil line goes directly into carb on left side,if has oil in line I would leave alone as pumps are pretty dependable,BUT if you have to disconnect make sure the carb inlet is blocked off.
Old 06-29-2009, 05:51 PM
hoytultratec's Avatar
incpecting the oil pumps ever so often insures you wont have a failure Ive had 2 2 strokes and never had a engine burn up but i did have one pump go to crap but stuck open I was wondering why it smoked so bad and i was going through so much oil. now I check it once a year and make sure the spring looks good and its staying clean inside. I hate premixing
Joe454
11-20-2020 01:19 PM
Jason An Stacy Jones
Utility ATVs
09-06-2015 02:25 AM
Quick Reply: Oil injection bypass
