Eiger drive belt
Old 07-16-2009, 04:38 AM
beart0y's Avatar
Default Eiger drive belt
My 2004 Eiger now has 16000miles on it-yes it gets used-and still origional belt. When dou you consider it needs changing?
Old 07-16-2009, 07:30 AM
TLC's Avatar
TLC
TLC is offline
I change them every 2000 miles even if the belt looks good, there only $80 and take 20 minutes to change.
16000 miles! My next ATV will be a Suzuki for sure now.
Old 08-04-2009, 04:03 PM
liv2hunt4x4's Avatar
2 minutes to do... Next time u change it can u post pics??
Old 08-05-2009, 04:16 AM
beart0y's Avatar
Well going with a Dayco belt. To change, does one put bolts into the rear sheaves to open it up and will belt then come off easily? The front unit doesn't have to be removed does it?
Old 08-27-2009, 10:54 AM
RonV's Avatar
I think I squeezed the one side open as much as I could and then slid the belt down inside. Then I turned it while slipping it on the variator side. It's been awhile, so sorry for the weak description. It wasn't difficult, I do remember that. I think I went with a Dayco belt for like $35. Got it at AutoZone of all places. Good luck & congrats on that many miles. That's something else. Out of curiosity, what have you had to change/fix over the years? I'm always fixing something. All the bearings have gone out, brakes all around once. I ride this one kinda hard.
Old 08-27-2009, 11:01 AM
TLC's Avatar
TLC
TLC is offline
You use no tools to take belt on or off you change it like a snowmobile. Here a Video of one being changed, it a Polaris but there all changed the same way. YouTube - Changeing belt POLARIS ATV
Old 08-29-2009, 03:23 AM
beart0y's Avatar
Well changed today. Old one had worn about 2mm. Still looks ok. Had to remove front pulley as no way was new one going on without. All goes like new noe.
Ridgebackguy86
09-19-2015 12:48 PM
Ridgerunner665
09-15-2015 01:20 AM
stcspiderman
09-13-2015 05:15 PM
Steeldon
09-09-2015 09:38 AM
Quick Reply: Eiger drive belt
