2005 Sportsman 700 code 41 and 45
Old 07-21-2009, 01:30 PM
briancbeck's Avatar
Default 2005 Sportsman 700 code 41 and 45
Does anyone know how to fix this. do i need to replace the sensor
I'm getting code 45(Air Temp-short circuit ground) and code 45-(Barometric Pressure Sensor low input.
Thanks for anyhelp that can be provided
Old 07-21-2009, 03:32 PM
PolarisPile's Avatar
Yeah...My 04.5 has had the same problem I have repaired mine too...I found what looks like a pretty good solution on ebay under the polaris parts electrical section for 35 bucks. It's an aftermarket wiring harness that lengthens up the harness and has a new wiring with a new connector..It's all water tight. and looks like its pretty good. The item number is 150359590605 I don't know if I want to buy it or wait till mine breaks again. I don't know if this is a one off or if the guy has more of them.
Old 07-22-2009, 09:06 AM
G.A.S.'s Avatar
Chances are it is not the sensor but the wiring harness. Check the wires going to the the t-bap sensor ( located under your seat infront of your air filter box. ) wires break inside insulation or insulation wears through and wires short to each other or to the chasis. I am on my third wiring harness due to this issue.
COFatboy
05-02-2020 12:06 AM
Jmuddin284
06-28-2017 04:59 PM
Polaris5
08-29-2015 09:11 PM
jldominic
Honda Side by Sides
08-08-2015 06:54 PM
Shifts
07-03-2015 07:59 AM
Quick Reply: 2005 Sportsman 700 code 41 and 45
