DS 650 Timing issues
Old 08-06-2009, 04:02 PM
nateshrek's Avatar
Default DS 650 Timing issues
I have a 2000 ds 650 that hasnt been running. We rebuilt the carb and found a blown head gasket. It has spark and fuel to the carb and compression. thinking its timeing. Does anyone know the specs on timeing??? or have any ideas?
-Thanks.
Old 08-06-2009, 10:17 PM
Big Ray 800's Avatar
Has a DS 800 Turbo Nitrous EFI money eating monster!
need to install a tdc locating screw and then line up the cam timing marks. when you changed the gasket how did you time it?
Old 08-07-2009, 04:19 PM
nateshrek's Avatar
havnt times it yet. we were wondering if it was timing or a ring issue.
Old 08-07-2009, 10:52 PM
nateshrek's Avatar
timed it by lining all four lines up in a straight line like it sayz to do in the manual. but still not running. we have spark air compression(amount unknown) and now timed. Any other ideas???
Old 08-08-2009, 04:56 PM
hsr-tm45s's Avatar
Just a thought when you did the head gasket, did you lock the crank down? it will have spark when the flywheel assy is 180dg off, when the cams are in line and piston is at tdc the flywheel should have the bump at about 12: oclock in line with the crank sensor. pull side cover or the center plug and look in to see if the key way is at 12: or 6: oclock.
Old 08-08-2009, 05:55 PM
aceisback's Avatar
Military Rider
My hobbies are NASCAR, Rockin' in the Free World, and riding my Sand Pigs at every available opportunity.
You have to make sure that when you line up the marks on the gears that the cam lobes are facing outboard/away from eachother. If they are pointing towards one another you are 180dg off.
robj
06-15-2015 08:45 PM
jag6510
06-15-2015 05:59 PM
Steven Bandemer
06-09-2015 08:50 PM
bbehrendt
05-28-2015 09:25 AM
Steven Bandemer
05-27-2015 07:39 PM
Quick Reply: DS 650 Timing issues
