lost key to 4wheeler, now what?
On the side of the ignition switch there is a set of 6 numbers/letters .. The last 3 are the key number Honda uses 4 possible keys lettered "A , B , C , D" so the last 3 digits will be something like "A81" or "B12" which is the key code (the same key code is on the old key/s) .. A locksmith could make you a key if you had the old key or if he has the key code info ..
We make Honda keys here is the code book and key cutter..
