how do you test the stator?
Old 09-11-2009, 12:56 PM
tmacdonald's Avatar
Default how do you test the stator?
How do you test the magnet stator when it is on the ATV but the ATV is not running? I can't get the ATV started and would like to test the stator before I tear the ATV apart. I've tested everything else.
Any help would be greatly appreciated!
Old 03-15-2010, 10:21 AM
cj420's Avatar
hey i am also having the same problem, suzuki lt230s, have tried everything, just doesnt seem like my spark is strong enough, how do i test the stator on these?
Old 03-15-2010, 07:24 PM
mikel1's Avatar
Sent you a pm
Old 04-03-2010, 01:05 PM
SundiroSunray90's Avatar
I too am actually having a similar problem...Sundiro Sunray 90. It doesn't really start, only pop. I think its electrical and the stator is something I think could be an issue.
Old 04-03-2010, 04:28 PM
cj420's Avatar
well lets start by diagnosing the problem. check all your wires and connections (most obvious thing to start with first). Second see if you have a spark?(pull plug out, find a clean surface on the head and crank it over, if its a fat blue spark, your Stator is good, and that will also tell you your cdi box is good.
What are you wrenching on? year/make/model
Im not by any means an atv/dirt bike mechanic but have learned abit here and there and have learned a few things talking to people
1 thing i was told if your stator goes, there is a chance it could retard your cdi box and set the ignition timming off....
But check your spark and get back to me with what your spark is like and anything you have tried and from what i have done myself and have learned from others i will try and help the best i can(everyday i learn something new)
feel free to email me if you would like
cj420@live.com
Old 04-03-2010, 10:18 PM
LynnEdwards's Avatar
Electrical Expert
You posted this in two different threads. I already answered this in the other thread before I saw this one.
CJ420's suggestion to check for spark is a very good one. If you do get a fat blue steady spark then the CDI and the stator ignition and trigger winding windings are good - just as CJ420 said already. This does not check that battery charging winding on the stator, but that has nothing to do with ignition.
I got the impression from your other post that you had intermittent spark. I assumed that you had done the classic spark test as outlined above by CJ420. But now that I read this post I'm not so sure. Definately do the spark test. The results of this test will define the next step.
Joe454
11-20-2020 01:19 PM
kbazzy
09-26-2015 11:26 AM
95scramblerruben1033
09-23-2015 06:29 PM
NRA+1
10
09-20-2015 08:47 PM
johnny1982
09-13-2015 07:41 PM
Quick Reply: how do you test the stator?
