atv wont run without choke
Old 09-14-2009, 01:57 PM
skywalker81's Avatar
Default atv wont run without choke
Hi everyone I am new to this site. I have a 98 kawasaki 400 I am trying to fix it wont run unless the choke is on. I thought it was a dirty carb I cleaned the carb out put it back together and I still have the same problem the second you take off the choke it stalls. any ideas
Old 09-14-2009, 02:38 PM
95wolv's Avatar
Sounds like the idle circuit is still plugged up, or your idle mix is too lean,another possibility is the idle is set too low to run without the extra gas from the choke. The pilot jet is critical in getting a good idle,and it has extremely tiny passages.
Old 09-14-2009, 06:40 PM
Doctorturbo's Avatar
GOT BOOST!
Your lean for some reason.
More than likely it will be what 95wolv suggested, a plugged pilot passage in the carb.
Don't forget to check for vacuum leaks which can cause a lean condition also.
Beeline08
11-11-2016 04:00 PM
wrencher82
09-30-2015 04:27 AM
wrencher82
09-28-2015 10:02 PM
2many2ride
09-27-2015 04:35 AM
wrencher82
09-24-2015 03:39 PM
Quick Reply: atv wont run without choke
