Polaris 400L 4X4 hub adjustment
Old 09-28-2009, 09:29 AM
joe d's Avatar
Default Polaris 400L 4X4 hub adjustment
Hi Guys
The Polaris atv 4 wheel drive system works good but once in a while the right tire will have a drag on it.It will pull the steering to the right. It seems to me the magnetic fields on the hub is causing the problem as the bearings and braking system is working fine. I've heard there is adjustment for the front hubs. If so how would that be done. any info would be appreciated. Thanks
Joe
Old 09-28-2009, 01:15 PM
TLC's Avatar
TLC
TLC is offline
Try changing your hub fliuds, Not sure od a adjustment I just know the hub castle nut is not to be tighter then 144 in/lb or 16 N*m. or 12 ft/lb.
Old 09-28-2009, 10:02 PM
mrtwostroke's Avatar
If you have a model with the stover lock nut. make sure to add in how much torque it takes to turn just the nut. remember just back up and it will fix it self. If it is doing it alot, clean the hubs all out. replace the retainer spring.
Jmuddin284
06-28-2017 04:59 PM
Gtsordo
07-13-2015 10:38 PM
coolguy420
07-09-2015 09:54 PM
cornermike
07-08-2015 11:44 PM
MNatv89
07-07-2015 11:36 AM
Quick Reply: Polaris 400L 4X4 hub adjustment
