Please Help!!! Predator 50 wont start elect.
Old 10-15-2009, 03:49 PM
kornhuzker's Avatar
Default Please Help!!! Predator 50 wont start elect.
I have a 2007 Polaris Predator 50.. it will not electric start.. have broke the kick start in the process, gas is getting in the air box, it turns over and over and over putts a little but never starts have had trouble starting this way entire time, waiting for a new kickstart to be delivered but would love to fix this anyways any ideas
Old 10-15-2009, 04:24 PM
LT80's Avatar
LT80 Expert
The fuel in the air box tells me that your carb is leaking fuel by the float needle. It's also filling the motor w/fuel thus flooding it. This is why it isn't starting.
Remove and clean the carb, removing both jets and the float needle and clean well.
Remove the spark plug and spin motor over till cylinder it quits spraying fuel out..**Use **caution** use a rag over the plug hole to catch the fuel AND do this with the ignition OFF so there isn't a fire**
Let it dry out, install spark plug. Kick start with the throttle wide open. let off after it starts and cleans out.
Maybe try that.
Old 10-15-2009, 05:19 PM
kornhuzker's Avatar
i will try this .. how particular do you have to be with the needle when putting it back together, also i dont have a kickstart at the moment it has snapped at the weld and currently waiting for a replacement to arrive
Old 10-15-2009, 07:56 PM
kornhuzker's Avatar
still nothing, turns over never starts, question: if there is a defaulted censor or something would there be a spark at the spark plug. started it with plug out still connected to wire and Ouhhh damn theres a spark. it has to be the carb but everything looks good removed both jets and all looks clean
Old 06-17-2012, 10:22 AM
sparks1032's Avatar
I am having similar problem but mine starts and then has no low end power I had to bend float bowl tab down 1mm to get it to start before that it would do nothin
cbcole02
09-07-2015 06:16 AM
Berjr
06-15-2015 04:41 PM
Predator_500
06-13-2015 03:01 PM
1000gade
05-27-2015 12:37 PM
Falcon150
05-25-2015 05:36 AM
Quick Reply: Please Help!!! Predator 50 wont start elect.
