Chinese Quad and Oil Filter???
Old 11-01-2009, 03:46 PM
JaCkaL829's Avatar
Default Chinese Quad and Oil Filter???
Hey guys,
I'm hoping to get some help. My cousin purchased a brand new Chinese 250cc 'utility' quad off of eBay a year ago. It has it's limits, but for the price he paid, it gets him where he needs to go. It's not the smoothest, but for the money whatever. It does require a little TLC, double checking and tightening bolts, and using loctite where needed lol.
Anyway, we would like to change the oil, and I'm sure any 4 stroke 10W-40 oil will be fine, but we're not sure what to with the oil filter? Any suggestions or help on finding one for it? I know parts are limited, but I'm hoping we can find an oil filter since that is something you would service. Anybody have any resources? All I know about the bike is its an 08 'T-something' or 'MX' it has the small circle headlights, like the yamaha grizzly bikes.
Any help would be appreciated. We have the owner's book but it doesn't mention anything of this. It's quite vague, and pretty poorly translated.
Thanks!
*edit* Here's a pic, it's the same exact bike except without a huge lift and all the auxiliary lights lol
Old 11-02-2009, 03:07 AM
aaronrkelly's Avatar
Does it even have a replaceable filter......most of these Ive seen have a screen setup and no user changeable filter.
But then Im not around the bigger machines like the 250s.....but a quick check shows no oil filter numbers that I can find on the Chinese 250s.
Old 11-04-2009, 09:42 PM
Scalerman's Avatar
JaCKaL829
On my 2008 Geo 250, I use Rotella 15-40 which works just fine. One of the brands
recommended on this forum for use on this type of engine with a oil base clutch.
No oil filter on these engine's. The 15mm drain plug is magnetic, which will catch any
metal filings.
My 250 takes 1.1ml of oil, also it's good to check the dip stick once your done.
Hope this helps.
Old 11-06-2009, 12:57 AM
95wolv's Avatar
Originally Posted by Scalerman
JaCKaL829
metal filings.
Hope this helps.
damn, a quart of oil must last you a long time if you only use 1.1 milliliter at a time !!!!!!
Old 11-07-2009, 07:18 AM
JaCkaL829's Avatar
So this particular quad (pictured above) I believe it's by a company called 'Tao', does not have an oil filter? That's good to know. I was planning on just using Maxima Premium ATV 10W-40 for this bike, along with my other 'real' bikes.
Old 11-07-2009, 06:40 PM
Scalerman's Avatar
95wolv
Good catch on my Typo.
What it should read is 1.1 liters of oil.
Thanks.
JaCKaL829
Make sure to check the dip stick when your done.
Old 11-07-2009, 07:33 PM
95wolv's Avatar
Is a liter about 34.something ounces?, I forget my conversions.
lightninboy
05-16-2021 09:52 PM
Frisky2050
04-09-2020 11:19 AM
cSchwartz
07-09-2015 02:43 PM
yambam13
07-04-2015 01:49 PM
D-Hagz
07-04-2015 02:19 AM
Quick Reply: Chinese Quad and Oil Filter???
