wont stay running?
Old 12-30-2009, 10:57 PM
asdfgh1's Avatar
Default wont stay running?
hi i maid a home maid chopper and it has a 49cc 2 stroke engine on it and it will not stay running its getting fuel spark and has plenty of compression it starts but wont stay running for not even 5 seconds. i used a smaller 2 stroke engine and its getting fuel spark and every thing and it runs just fine. ima using the same carb same plug same fuel and every thing why wont the 49cc stay running? any help will be appriciated thanks
Old 12-31-2009, 12:01 AM
Doctorturbo's Avatar
GOT BOOST!
Check for a plugged exhaust pipe
Old 12-31-2009, 05:27 PM
asdfgh1's Avatar
i did every thing is unclogged but the crank shaft is hard to turn and on the other motor the crank shaft turns fine so could that be a problem?
Old 04-24-2010, 08:35 PM
Yummymummy's Avatar
Been having the same problem and took apart the carb 3 times, cleaned it, you name it, checked everything. Then a buddy told me he had the same problem and it was the needle in the carb sticking. It allows the carb bowl to fill up and then empty but then doesnt drop to allow refill. He said to just buy a new carb, they are about $30 cnd if you can find one. Don't quote me tho, I havent tried that yet. Im gonna try cleaning the needle 1st, then buy a new one if I have to.
Good luck & keep us posted
whitty
67
02-24-2021 02:52 PM
MikeyBoyesq
11-27-2020 02:44 PM
Dame0927
10-29-2015 10:13 PM
jayking232003
06-09-2015 02:54 PM
blaze_master
05-26-2015 11:18 AM
Quick Reply: wont stay running?
