Kodiak 450 headlight - not the usual ?
Old 01-06-2010, 06:06 PM
Kcolg's Avatar
Default Kodiak 450 headlight - not the usual ?
Trying to remove and change the headlights on my '04 Kodiak 450, but I can't get the buld and socket out of the black plastic housing. I have them out of the reflective lens part, but there is not enough wire length to pull the socket and bulb out of the little hole in the back so I can change them. Is that common? or is there a trick to it that I'm missing?
At this point the only options I see are...
1. Cutting the 3 wires to get it out and then having to rewire it with longer ones to re-install.
2. Pulling hard on the wires to see if I can get some more wire to feed out from under the front of the atv.
3. Break the bulb and then pull the housing out, but then after I re-install a new bulb how the heck do I get it back in there since the wires seem way to short.
Old 01-07-2010, 08:41 AM
Kcolg's Avatar
Nevermind, finally got them out. Took a while to twist the whole thing around and find a way to get it out. If Yamaha would have made the wires 6" longer it would have made life a lot easier changing these expensive lightbulbs.
Old 01-07-2010, 03:05 PM
Hill AK's Avatar
Yeah and then the headlights suck...one of mine seems to always go dim...I give it a good thump and it brightens back up----glad to see you figured it out!
ultangler
09-05-2021 08:06 PM
EIF
04-20-2017 07:15 PM
Whitelx1
10-02-2015 10:55 PM
Sw00p
09-24-2015 02:50 PM
Quick Reply: Kodiak 450 headlight - not the usual ?
