Carburetor problems
Old 01-18-2010, 02:22 PM
Thundare's Avatar
Default Carburetor problems
Hey guys, I have a 1990 yamaha 350 warrior and its got some carb problems. Right now it leaks fuel through the over flow when not running (Pretty sure that is the floats problem) it only runs with full choke on and it kinda makes a popping sound but its not a back fire, just sounds like a bunch of vapor coming out the exhaust. all this happend after i put some new gas in it, maybe the fuel was bad and carb cleaner might work?
Old 01-20-2010, 02:54 PM
yellowdemon23's Avatar
Could be some bad gas. Have you ever had this problem before. As for the gas coming out of the bowl thats because of your float isn't set right allowing gas to seep out around the needle.
Old 01-20-2010, 05:41 PM
Thundare's Avatar
well i just took it for a carb clean, we will see if it fix's the problem.
Old 01-26-2010, 08:13 PM
Thundare's Avatar
yep a carb clean fixed 100% bad gas. the guy actually had to drill the crap out from the jet, pretty bad.
Old 01-27-2010, 03:20 PM
wolfshowl28's Avatar
i would go a step further and clean your gas tank out, fuel pet ****, and fule lines and make sure all has a tight seals. seals are key for preventitive maintnance.
Old 01-28-2010, 02:40 AM
Thundare's Avatar
i already drained all the fuel out but im just going to put a fuel filter on the line before the carb to make it easy :P
Old 01-28-2010, 08:53 AM
yeah that helps. i use the winter months to go through my atv's and dial them in to make sure there mint come spring. then its muddin time!
Old 01-29-2010, 04:49 PM
you do know that the fuel petcock has a fuel filter in it though right?
greg74
09-10-2019 03:03 PM
ogio117
Polaris Side by Sides
04-29-2019 03:14 PM
kelleycully
09-15-2016 02:57 AM
hondarider1234
07-21-2015 11:53 PM
Shifts
14
07-13-2015 08:41 AM
Quick Reply: Carburetor problems
