Polaris Xplorer 4x4 not working
Old 02-06-2010, 10:19 AM
Ehonpar's Avatar
Default Polaris Xplorer 4x4 not working
I have a Polaris 400 Xplorer... The four wheel drive does not work in forward but will engage in reverse if you hit the over ride switch.
We have been getting a lot of snow and I have a snow blade for it but it is useless right now.
Even if I could engage the 4 wheel drive manual would be a help
Thanks in advance
Dan
Old 02-06-2010, 11:34 AM
xplorerman's Avatar
try holding the gear shifter ahead when in 4x4 see if that works
Old 02-06-2010, 04:19 PM
Ehonpar's Avatar
Tried, did not help... really works well in reverse. any other ideas?
Old 02-06-2010, 07:15 PM
Ehonpar's Avatar
Is it possible that the 4 wheel drive is also tied into the head lights? Started tracing wires and strangley enought it goes to the head light on the handlebars high/low beam...
Things that make you go hmmmm.
Thanks
Dan
Old 02-06-2010, 07:19 PM
stendori's Avatar
I'm watching you!
i think your going to find it has to do w/ the override switch/wiring being the issue.
Old 02-06-2010, 07:40 PM
ddesens's Avatar
I just had a similar issue with mine. The trans switch was acting up. Really move the shifter forward and all around to see if the light goes on and off for the awd.
Old 02-06-2010, 08:18 PM
stendori's Avatar
I'm watching you!
i agree w/ checking the switch as that tells the bike what gear it's in and when the override has to kick in. you should be able to by pass it.
Old 02-06-2010, 09:14 PM
Ehonpar's Avatar
Don't guess anyone has a manual for this....
Old 02-07-2010, 10:03 AM
Ehonpar's Avatar
Where is this "trans switch" ????
Thanks
d
cornermike
06-03-2015 07:27 AM
cornermike
05-27-2015 10:04 PM
rsoxfan
05-30-2000 12:23 AM
rsoxfan
05-28-2000 03:27 AM
Quick Reply: Polaris Xplorer 4x4 not working
