2001 Magnum 325 4 wheel drive problem
Old 02-17-2010, 04:21 PM
atr537's Avatar
Default 2001 Magnum 325 4 wheel drive problem
I recently just replaced the front right cv shaft, cv shaft bearings, hub and u-joint on my 2001 polaris magnum 325 4x4 and when i engage the 4 wheel drive only the front left tire spins and i can hold the right one while hitting the throttle when its jacked up. any help appreciated
thanks, Ryan
Old 02-17-2010, 05:42 PM
stendori's Avatar
I'm watching you!
welcome to the forum. did you put the correct polaris hub oil back in?
Old 02-17-2010, 05:59 PM
atr537's Avatar
thank you and no i havent put any oil in it yet but i did pack the bearings with grease. do you know what the oil is called because i bought an oil change kit that comes with various lubricants so i probably have it
Old 02-17-2010, 06:03 PM
stendori's Avatar
I'm watching you!
it has to be the correct oil for the hubs to work and only the polaris hub oil is correct so you'll have to go to the dealer and buy it. someone might have a part number handy to show to you. but dont sub. out for differnt oil of it will not work.
Old 02-17-2010, 06:08 PM
atr537's Avatar
alright thank you
Old 02-17-2010, 06:37 PM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
The fluid you need is demand drive fluid part#2871654 or demand drive plus part#2877922. My dealer does'nt carry the first number anymore but tell me the demand drive plus is basically the same thing. I've been using it for about a year now and can't tell any difference from the old stuff. (maybe just a number change?)
generalpops
06-05-2015 08:23 PM
volsgo30
06-04-2015 06:07 PM
generalpops
06-03-2015 08:25 PM
Tray
01-14-2001 03:18 PM
caldwell
10-28-1999 03:30 PM
Quick Reply: 2001 Magnum 325 4 wheel drive problem
