Kazuma 110 falcon no spark
Old 04-14-2010, 08:21 PM
Geo 05's Avatar
Question Kazuma 110 falcon no spark
Hello I am new to this site my son has a kazuma 110 falcon that was running fine then started to let warm up to ride idled for about 1 min. then quit and would not start back up checked and found it had no spark installed new cdi box, sparkplug and coil still have no spark can anyone help thank you. The atv is a 05
Old 04-14-2010, 09:45 PM
mikel1's Avatar
Disconnect the cdi from the connector , push out the kill switch pin(black with white striped wire) on the connector. Ground spark plug to head or use tester, try to start and check for spark. If it sparks then problem is with one of the kill switches or the wiring.
Old 04-15-2010, 11:24 PM
LynnEdwards's Avatar
Electrical Expert
I completely agree with mikel1.
Old 04-25-2010, 05:13 PM
jamietavis's Avatar
hello i have a 110cc chinese motor can anyone help me with wire diagramor what wires go were?
Old 04-25-2010, 05:35 PM
jamietavis's Avatar
i got the same problem some one help me with the wire diagram. please thank you!
Old 04-26-2010, 12:27 AM
Electrical Expert
This was posted on this forum earlier. It may not be your quad exactly but most 110cc quads are wired very similar. This quad diagram doesn't have a remote though. The wire colors may not match but the wire routes will be similar.
What kind of problem are you having?
Old 04-28-2010, 06:00 PM
towery3's Avatar
ive got the same problem on a 110 panther put a new coil and still no fire had to wire the wires that go to the brake toget ittoturn over but someone said diconcet cdi box take a black n white outout pigtail but after that do i reconncet cdi before testing
towery3_2001@yahoo.com
Old 04-28-2010, 06:39 PM
mikel1's Avatar
I have a Panther of my bro-in-laws in my backyard. Do exactly what I put in my above post on the black/white striped wire. Also make sure the green wire is grounded good near the stator assembly, his Panther only had 1 wire strand attaching the ground wire. If that doesn't help let me know.
Old 04-28-2010, 08:23 PM
towery3's Avatar
after i disconnect this wire do i rehook up the cdi box or just take the black-white wire also does it mater which wire goes on coil the coil had a green term i put green wire there the other is a ground
Old 04-28-2010, 09:35 PM
mikel1's Avatar
Yeah, hook the cdi back up then check for spark. On this panther the gound wire is the green wire which is grounded on a small plate on the ignition coil, the black/yellow striped wire goes to the terminal.
Quick Reply: Kazuma 110 falcon no spark
