Charging new battery
Old 04-16-2010, 02:41 PM
bweymouth's Avatar
Default Charging new battery
I just bought a new Yuasa battery for my sons Polaris Sportsman 90. I added the acid and put it in the quad. I turned over great and started right up. Do I need to charge the battery right away after adding the acid? If so, for how long?
Old 04-16-2010, 02:45 PM
Jaster94's Avatar
the box the battery comes in should have a chart in there to give you the times. the last time i bought a battery, it told me about 4 hrs. i haven't looked back since on my batteries. hope this helps!
Old 04-16-2010, 02:52 PM
Jaster94's Avatar
you may check with the dealer you bought it from unless you find the paperwork. i'm thinking you may not want to go more than 2 amps while charging for 4 hrs.
Old 04-16-2010, 04:31 PM
bentarrow's Avatar
First Things First!
If your charger goes as low as 2 amps that would be best, if you don't have any way of telling the volts or a charger with automatic shut off be careful not to boil off acid. Full charge should be around 12.8 volts after it sits for an hour after charging.
Old 04-16-2010, 04:41 PM
stendori's Avatar
I'm watching you!
you should have let your battery set about 30 minutes after adding the acid to soak into the plates then charge it for say 8 hours on a slow charge like around 2 amps for the best life of the battery. imo
Old 04-16-2010, 11:27 PM
chuck_raduenz's Avatar
agreed shoulda let it set. then top it off to the marks. chage at a slow rate for least 8hrs. then put it in.
Old 04-17-2010, 12:38 AM
Spdecat's Avatar
Old 07-15-2010, 04:53 PM
Spdecat's Avatar
Originally Posted by Spdecat
If you live in Canada , Canadian Tire has the CTEK charger on sale 40% off next week .
Steeldon
09-09-2015 09:38 AM
Steeldon
Utility ATVs
09-05-2015 09:38 PM
toonces
09-05-2015 01:14 PM
Pahuntman
09-05-2015 11:07 AM
momma's bike
08-06-2015 09:49 AM
Quick Reply: Charging new battery
