Lakota puking gas..?!
Old 05-01-2010, 08:02 AM
iamnothing's Avatar
Default Lakota puking gas..?!
One of our Lakotas is leaking gas right out the drain tube when the motor stops running. I'm not a mechanical guru like some of you guys, but I took it out and everything seemed tight. The drain screw (allen keyed) is tightened up, but the gas leaks right out. This happens when the motor is shut off, or when trying to start (I say trying because it doesn't always, but I'm gonna try a new plug). If the petcock is off, it's good, but if it drained I need it back on to start it, and if it doesn't start, it leakes right back out. It also doesn't run on "on", I always use "reserve", if that means anything to you guys... Any input would be appreciated, thanx.
Old 05-01-2010, 08:12 AM
TLC's Avatar
TLC
TLC is offline
You carb needle valve is not sitting right, you need to clean it or change the rubber o ring or set the float hight of the carb.
Old 05-01-2010, 08:41 AM
iamnothing's Avatar
Thumbs up
I will check all 3, thank you.
Old 05-03-2010, 04:38 PM
Kerbbirds's Avatar
Needle and seat are probably worn, check engine oil and air box for gas, this could be why its hard to start.
Old 05-04-2010, 08:18 AM
faruquehabib's Avatar
wow, i can't believe this post is here. I was just about to post that my Bayou 250's are sputtering when i hit the throttle, and one of them after riding fine and then shutting down, will leak gas out of the tube that goes from the carb to the bottom of the machine. this lakota issue is identical it seems like. I was going to replace the plugs, and was guessing it was a carb issue.
how difficult is it to take apart the carb? i've never done it before, i am not a mechanic, but i do have common sense and can read my service manual. i don't know the parts named off above by looking at it, so i am wondering if anyone has advice on whether i should be able to do this myself (tear down carbs and rebuild) or if i should just take it to the dealer. i do not intend to hijack this thread, just want some advice on the same subject.
Thanks!
Old 05-04-2010, 08:31 AM
anyone know where to get a rebuild kit cheaper thean this?
ATVWorks.com
Old 05-09-2010, 02:19 PM
kawi440's Avatar
Is sounds like the floats are stuck, thats happened to me and i just tapped lightly on the float bowel with the end of a screwdriver to free it up, you may also have a dent or something wrong with your floats in the carb.
raceware
07-30-2015 06:59 AM
kwackermann
06-24-2015 10:18 AM
KawasakiLakota
08-23-2000 11:57 PM
blazer1969
08-23-2000 02:45 PM
cstark
10-15-1999 01:45 PM
Quick Reply: Lakota puking gas..?!
