namura piston bad?
Old 05-07-2010, 10:58 PM
2006dvx400's Avatar
Default namura piston bad?
I have a 1999 trailblazer 250 and was recently rebuilding the motor. I put a namura piston in it and as i went to look in the intake port after finishing the motor i noticed where the bottom ring ended the small pin in the piston it was in the middle of the intake port and is slightingly catching the port. This is a brand new piston and i was just wondering if anyone alse has had this trouble with a namura piston. I have called them and they said it would be fine to run.
Old 05-08-2010, 04:02 AM
mrtwostroke's Avatar
Well my thought is the oem piston must have done this too. As strange as that would be. Did they say it would be fine to run, or did they say it was designed that way. Two totally different scenarios.
Old 05-27-2010, 08:58 PM
zackzack6's Avatar
am in the middle of a build on a 98 300 polaris and using the namura was wondering if anyone knows the amount of allowable crank up and down play
Old 05-28-2010, 04:09 AM
Kerbbirds's Avatar
Not sure of exact measurement but there should not be very much, better have rod bearing thouroughly checked, sounds like it may have problems.
exmotocrosser
09-13-2019 06:12 AM
2many2ride
09-27-2015 04:35 AM
Quadzilla Heritage
09-25-2015 01:39 PM
dunerv8
Technical and How-To Articles
09-14-2015 10:11 AM
nastyblaster100
09-13-2015 01:19 PM
Quick Reply: namura piston bad?
