gy6 150cc starting problems
Old 07-01-2010, 12:44 AM
balboabob's Avatar
Default gy6 150cc starting problems
HI,
I have no problem starting my engine when cold, starts with one click of the starter.
When warm, it is very difficult and somtimes will not start at all, I have to let it sit for some time then it will start.
I checked the spark when it was hot and at first got a yellow spark, then no spark at all.
Can anyone help?
Bob
Old 07-01-2010, 11:37 PM
LynnEdwards's Avatar
Electrical Expert
These kinds of troubles can be frustrating. Some thoughts:
The electrical components that make spark don't really get that hot (CDI and coil). They really don't even get heated by the engine that much because they are mounted in a moving stream of air so they would never heat up very much while you're moving. You could always try heating those parts up with a heat gun, or really strong hair dryer and see if that affects spark. They're both pretty big thermal masses, so heat them up slowly over a 10 minute period minimum to make sure they are heated through to the center, and not overheated on the outside.
The stator does get hot. The trigger pulse that tells the CDI to fire comes from here. If your CDI is AC powered (still the most common, but becoming less so on newer quads) then this power comes from the stator too. These can be measured, but you'll have to do this when the engine is hot and the quad is not making spark. Do you know if your CDI is AC powered or DC powered? Do you have a meter?
The spark plug gets hot too. The only way to test this is to change it. Presumably, though, you measured spark when the plug was cool enough to handle.
It would be unusual for kill switches to only malfunction when the engine is warm. But once again this can be verified or eliminated with some meter measurements while you are having no spark.
The first step is to get a meter, find a way to make the quad go into the *no spark* mode. If you know how your CDI is powered then we can start down one of two different paths. If you don't know then say so and we'll find that out with some simple measurements before starting down the DC or AC path.
Intermittents can confound the best technicians. It is easy to think the quad is malfunctioning when it is actually working fine (like the kill switch accidently left on during a test). That sends you right down the proverbial garden path. Don't be afraid to retreat, verify previous tests, and change direction if necessary.
Old 07-02-2010, 12:12 AM
balboabob's Avatar
Hi Lynn,
I see you live in Tracy, I spent 5 years in Stocton in the early 90's. I hope you are not disapointed, by I am referring to a scooter, I have been to some of the scoot sites but found the information more informative here so I thought I would give it a try.
I do have a meter so i will test the CDI to see if it is AC or DC.
I have a new spark plug in right now, but used a different plug for the test, this makes it easier when the engine is hot. Apparantly when cold the spark is fine, the engine starts immediately upon pressing the starter.
I had the battery tested today and it is good, as I suspected, because it will crank forever if I want it to.
I found that if i open the compartment and lift the seat up, the cooling will be quicker and i can restart in about 30-45 minutes.
I hope we can solve this together.
Old 07-02-2010, 01:42 PM
balboabob's Avatar
Lynn, OK, According to the diagram i have this is an AC CDI unit.
Old 07-02-2010, 10:10 PM
Electrical Expert
No problem on the scooter angle. Some of the best GY6 service manual stuff is published by scooter vendors. Without scooters, us GY6 quad riders would be at a real disadvantage for service information.
I'm thinking this is your CDI:
I'm still thinking stator, since that is the only thing that would take 30-45 minutes to cool after shutting off the engine. Two things come off the stator which are involved in making spark: The AC ignition power winding, and the Timing trigger pulse.
While the engine is hot and you are not getting spark:
1) Unplug the CDI.
2) Measure the AC voltage on the AC Ignition Power pin of the wiring harness to ground while cranking the engine. You should measure 50 to 80 volts AC.
3) Switch the meter to the lowest AC voltage you have. Measure the Timing Trigger pin AC voltage to ground while cranking the engine. You should see 0.1 to 0.4 volts AC.
4) Switch to measuring resistance (ohms). With the engine stopped measure the AC Ignition Power pin resistance to ground. You should measure 450 ohms or so.
5) Also measure the Timing Trigger pin resistance to ground. You should measure 150 ohms or so.
Again you must do all this while you are getting no spark, so make sure that you don't have spark at the beginning of the tests, and verify that you *still* don't have spark at the end of the tests.
Old 07-21-2010, 06:45 PM
balboabob's Avatar
Default fixed
Ok, I put the new stator in and it has been a week with no problems, I assume we got it. Thanks for everyone's help.
Bob
Old 07-21-2010, 10:34 PM
Electrical Expert
Glad you got it running.
Old 10-08-2010, 12:11 PM
fffitz0117's Avatar
i bought a kasea 150cc adventure buggy it will start then die after a second or 2 anyone have a ideal whaT IT COULD BE CLEANED CARB AND AJUSTED VALVES IF THEY ACTULLAY SET ON .005 DONT KNOWW YEAR JUST A 150CC KASEA WITH D SHAPE VALVE COVER HELP PLEASE
generalpops
06-05-2015 08:23 PM
garyt1975
06-05-2015 08:53 AM
Jaster94
3) General Discussions..
05-29-2015 08:45 AM
1000gade
05-27-2015 12:37 PM
elmer119
05-24-2015 10:51 AM
Quick Reply: gy6 150cc starting problems
