Front CV joint loose in diff
Old 08-03-2010, 08:08 PM
EastCoastWest's Avatar
Default Front CV joint loose in diff
Yeah, I know it's not really a diff, you knew what I mean. The CV joint is loose, I can grab it and wiggle it around. It's not the shaft itself, it's where it goes into the front drive unit. It's the left one only, not the right. I can also hear a new rattling noise and can also feel it through the bars, I believe this is where it's coming from. Is this common? What's the fix?
Old 08-03-2010, 11:00 PM
TLC's Avatar
TLC
TLC is offline
If its the CV worn (under the black rubber boot) on the axle then you have to buy a new axle,they do not just sell CV joints separate,which would be nice if they did.
If its not the CV,then its in the front diff. I would guess roller cage if the AWD is not working.
Old 08-04-2010, 06:09 AM
It's not the joint itself, it's where the shaft couples with the front gearcase. I've never had one out before, what holds it in? Does it ride in a bearing?
Old 08-04-2010, 07:23 AM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
Does it wiggle up and down or in and out? Your axle is a splined shaft with a groove in it for a compression ring. The compression ring is what holds it in place. If you can wiggle it in and out I would suspect the ring is weak, not seated properly, or broken which I've never seen but not impossible. If it wiggles up and down I would suspect possibly a bearing or roller cage in the front drive housing.
Old 08-04-2010, 11:00 AM
It's up and down, it doesn't wiggle that much but the other side doesn't wiggle at all. The awd works fine so it could be a bearing I guess. Do you know if the case needs to be pulled and split to replace the bearings?
Old 08-04-2010, 11:25 AM
TLC's Avatar
TLC
TLC is offline
Not sure if the Diff would come apart for the bearing, not as bad as you think if be, I hear of people changing the roller cage and saying it was not that bad of a job.
According to this parts site OEM motorcycle and ATV parts from Honda, Yamaha & Polaris – Cycle Parts Warehouse you should find out if your ATV was built before or after 7/17/06 also a different diff if its ADC. so three possible front gear cases for a 07, 800.
Old 08-04-2010, 11:52 AM
It was built in March of 07, I would hate to have gotten one of the early builds. I'm really thinking of getting rid of it at this point. It seems like I fix more than I ride.
Old 08-04-2010, 02:19 PM
stendori's Avatar
I'm watching you!
guessing but sounds like the bearing or maybe carrier is the issue. not very common that i have herd about.
Old 08-04-2010, 03:55 PM
when you say a little wiggle, how much? I checked my sportsmans to kinda compare what your saying and both sides of mine wiggle slightly up and down but not front to back. I only have 600 mile on it so far, and noticed zero issues with it the way it is. I wonder if it's normal to have just a little give.
Old 08-04-2010, 07:42 PM
Possibly, it is only held there with a small clip. I think the rattling noise I'm hearing is my wheel bearings getting bad... 2000 miles.
STLyamwar
07-25-2020 04:44 AM
metal249
07-28-2015 09:35 AM
carolinabomb
07-26-2015 08:40 AM
Peter_
07-18-2015 07:06 AM
musselmark
07-17-2015 02:40 PM
Quick Reply: Front CV joint loose in diff
