09 kingquad oil capacity
Old 08-25-2010, 12:42 PM
unit6666's Avatar
Default 09 kingquad oil capacity
Anyone know what the engine oil capacity is on a 09 kingquad 500 with a filter change? thank you!
Old 08-25-2010, 12:54 PM
CVT11's Avatar
check the owners manual.i couldnt find anything on their website
Old 08-25-2010, 01:22 PM
unit6666's Avatar
If I had a manual I would have checked it LOL
Old 08-26-2010, 06:53 AM
2strokezilla's Avatar
check on engine case side close to where you put in oil most models will show oil capacity there
Old 08-26-2010, 07:31 PM
Mud Slinger's Avatar
Go to PartShark.com --- Motorcycle Parts, Accessories, Apparel, & Merchandise. and click on downloads. You can download an owner's manual there for free. You can also download a service manual there for free. This should help you out!
Old 08-27-2010, 10:20 PM
stillV1's Avatar
I believe it is 2.6 quarts with filter
Old 10-06-2010, 02:21 PM
King Quad's Avatar
2.6 quarts and get the wrench for the filter.
When you attatch the filter I believe once it is tight you want to turn it 2 rotations.
They suggest you mark the filter. ( I just marked my wrench)
Old 10-06-2010, 03:51 PM
Boss Man's Avatar
Yep, the capacity is approximately 2.6 quarts.
The trick is to get the quad level enough to get a good measurement.
After you have put the new filter on, and added about 2.6 quarts of oil...
Screw the dipstick in, and start the motor up and let it run a few minutes.
Shut it off and let it sit for a few minutes.
Take the dipstick out, wipe it off and put the dipstick back so that the threads just touch the filler hole upper edge. DO NOT screw the dipstick in to check the level.
gogogo
10-15-2015 05:40 PM
antiguogrumete
09-05-2015 03:41 AM
Stirling
08-11-2015 07:23 AM
Quick Reply: 09 kingquad oil capacity
