Honda Rancher ESP Problems!! Please help
Hey everybody im new to this forum. I have a 2001 Rancher 350 2x4 ESP. When I am cruising down the road and leave my fourwheeler in gear for to long it will not shift up or down. Unless I come to a stop and shut the four wheeler off and turn it back on. But if I shift up and back down fast it seems to work fine. Has anyone had this problem or know what it can be. Ive had a couple of four wheelers in the past but never one with ESP so im kinda new to this electric shift stuff.
My fourwheeler has about 600 hrs on it and it has been sunk in water before. The guy that sold it to me has had everything professionally fixed and its been sitin in a garage for about 2 years.
Thanks
Thanks
I had the same problem with my 450 forman and I checked the fuse on mine and it worked for a while...then it did it again the shop i got it from told me to take off something and clean it...I do know there is something called an angle sensor probably search for that??I never fixed mine I just use the tool...good luck
more than likely you have an angle sensor problem if the display flashes when this happens. the sensor is located on the front of the machine next to the shift motor its an easy twenty minute job. 5mm allen and 10mm socket is all the job requires. It is half moon shaped so make sure you align it when installing.
