2002 Yamaha Breeze YFA1
Old 10-17-2010, 03:17 PM
pjmia96's Avatar
Post 2002 Yamaha Breeze YFA1
I have a 2002 Yamaha Breeze YFA1 and I have a few problems.The first problem is my ATV smells like oil when it is hot.Not only that it also leaks oil out of the hole on the bottom of the gas of and on switch when it is very hot.The oil will leak everywhere causing it to smoke when the oil touches a hot engine.The gas tank has a hose that goes into the gas off and on switch so I'm hopeing its not gas.
Second Problem I have to wait for my ATV to idle down Every time I start it up or it slams into gear when put into drive.Also when its very hot it wont idle down and if I put it into drive it slams into gear.
My third problem is its hard to put it into reverse.The lever doesn't move easily it should move easily in and out of gear.It will go in forward,and neutral easily but reverse requires some force but reverse does work.
Please Help me I want to get my ATV running better.
Old 10-17-2010, 07:08 PM
TexasRoadlawyer's Avatar
No Ruts, No Glory
The Breeze is not a two stroke, so oil would not be leaking out of the gas.
If it is smoking when it hits the hot engine, it is oil.
Have you taken the tank off to get a better view of the engine to see where oil is leaking from? Just a guess, but maybe the seal for the valve cover is leaking causing oil to spray out onto the underside of the tank, making it appear like oil is leaking from the gas tank.
Your idle is set too high, which may be the root of the reverse problem you are experiencing.
These are fairly easy fixes if you know how to find them....no offense meant, but you might be better off taking the machine to a professional mechanic
Old 10-17-2010, 08:11 PM
pjmia96's Avatar
Default valve cover?
what is the seal of the valve cover called? Does it have a specific part name?
Old 10-17-2010, 09:35 PM
No Ruts, No Glory
take a look at the Yamaha of Troy site...there is a parts microfiche locater that will illustrate what I'm referring to...it's part 10
Yamaha of Troy
It's a cylinder head cover o-ring...but like I said, I'm just guessing as to the cause of the leak
Old 10-18-2010, 12:34 AM
Doctorturbo's Avatar
GOT BOOST!
#2 is cause by your choke plunger hanging up. You need to take it apart and clean up the bore.
BigT137
3) General Discussions..
08-19-2015 12:09 AM
ghost civic
07-30-2015 04:09 PM
ghost civic
07-27-2015 03:15 AM
ghost civic
07-15-2015 10:48 PM
cSchwartz
07-09-2015 02:43 PM
Quick Reply: 2002 Yamaha Breeze YFA1
