Questions - CPI Bullet 90cc
Old 12-29-2010, 08:37 AM
s0eebuch's Avatar
Default Questions - CPI Bullet 90cc
Hey all. A buddy gave me a CPI bullet 90 that wasn't running.
I got the carb adjust to where it will run but it still isn't fantastic. I either have idle with the choke closed (and it bogs down at full throttle, under load - like it is getting too much fuel) or I can get it to scream at full throttle with the choke open (and it doesn't want to idle).
Any advice?
Also, the gas tank is leaking at the outlet spout. Where can I finda replacement? I see "generic" tanks on Ebay but I can't find anything that tells me it is a direct replacement for a CPI bullet 90.
Thanks!
Old 03-18-2011, 09:29 PM
Skydog12's Avatar
Default Same problem
Hey i have the same problem with mine.Did you find out what it was because I have been trying to figure it out?
Old 03-18-2011, 09:58 PM
95wolv's Avatar
You guys gotta start using the internet, I googled "CPI bullet 90", and got lots of info, including a website with a 36 page pdf file (only 18 pages total) showing all body, frame and electrical and engine parts with part numbers from Parts For Scooters ATVs buggies GoKarts Vespa Piaggio Kymco SYM PGO Aprilia Eton Apex Kinroad Carter . This took me all of maybe 2 minutes to do, including typing out this post !! There were also several other sites to check out, just google it and you will find what you need, complete with part numbers.
As far as your idling problem, its probably the pilot jet gummed up, it controls fuel flow for idling, you need to take carb apart and clean it out, it probably sat a while and got all varnished up, thats why it will run with choke or full throttle, you are bypassing the idle circuit when you do that.
Old 03-18-2011, 10:33 PM
Skydog12's Avatar
I found that stuff..I just need a wiring diagram of it.Do u know where i can get one?
Old 03-18-2011, 10:37 PM
Skydog12's Avatar
We have also cleaned the carborator like crazy so it is not that for sure
bigred20653
10-02-2015 10:05 AM
MPDano
09-20-2015 09:48 PM
Chasso
2) Chassis problems..
09-19-2015 03:06 AM
MrTrashMan2U
09-09-2015 11:44 AM
MrTrashMan2U
09-09-2015 11:11 AM
Quick Reply: Questions - CPI Bullet 90cc
