2002 Honda recon es 250 wont shift out of neutral
Old 02-10-2011, 03:14 PM
kolobok101's Avatar
Default 2002 Honda recon es 250 wont shift out of neutral
Hi all, I’m having problem with my 2002 Honda recon ES 250, I recently replaced angle sensor and bike shifts and runs great but suddenly when I put it in neutral it would not shift to any gear no sound at all, so I had to shut it off and back on and it works fine, and I noticed it its only gives me that problem when I was riding through 1 ½ feet of snow. But when it nice and dry out side works fine, any ideas.
Thanks
Old 03-03-2011, 10:09 AM
wvgoofy's Avatar
check plugin on bottom/back of motor it can come unpluged or loose
Old 03-05-2011, 06:45 AM
honda_recon_ beast's Avatar
try shaking your atv like rocking it back and forth. I have had the same problem when I flipped my recon, and thats what i did so i hope this helps!!!
Old 03-05-2011, 08:31 AM
zitaron's Avatar
did you replace the rubber seal on the angle sensor?
Old 03-07-2011, 10:49 AM
kolobok101's Avatar
thanks for reply, i noticed yesterday after 1 hour of riding my recon it was riding fine but after i put it in neutral the rpm goes up and i cant put it in first gear because of high rpm i don't know the reason why rpm goes so high is it because the bike is hot, so basically i have to pull the choke up so rpm goes down a little and than i can put it in gears and rides fine till again when i put it neutral. so something going-on with high rpm when in neutral hopefully i explained right. any ideas will be appreciated.
thanks
Old 03-07-2011, 09:10 PM
kolobok101's Avatar
yes i did, i don't think its angle sensor,
greg74
09-10-2019 03:03 PM
Lpshann
Sport Quads
07-29-2015 08:11 AM
Kodiak-vic
07-29-2015 03:06 AM
ScopeZ_
07-28-2015 01:44 AM
MNatv89
07-07-2015 11:36 AM
Quick Reply: 2002 Honda recon es 250 wont shift out of neutral
