Wolverine Overheating......confused!
Old 02-19-2011, 12:09 PM
JakeROFL's Avatar
Default Wolverine Overheating......confused!
Ok, im going to make this short and sweet.
The fan does not come on anymore. So now the bike just overheats.
The first thing I did was check the fan. I bypassed the fan and it worked! So now I know the fan is good.
The second thing I did was check the radiator sensor (whatever you want to call it). I can't tell if it's good or bad so I just bought a new one because it was cheap. I put the new one in and .. still not working.
Third and last thing I did was remove the thermostat and test it. The thermostat open and closes!!!!!!
Now i'm lost. I thought it would be one of these three things. What else could be making the fan not come on?? Don't even say a fuse because there is no fuse for it.
Any help would be great, because im lost now!
Old 02-19-2011, 04:41 PM
mudslinger2's Avatar
I haven't been stuck since the last time!
Default What year?
What year wolverine are we talking? Liquid or oil cooled? I know that my brother had trouble with his kodiak...there is a sensor in the radiator and a sensor in the block that control two different things I think. One tells the fan when to run and one tells the light to come on. Is it spewing coolant out when it overheats? I would start with a downloadable service manual...that will take you through the issue that you are having step by step...good luck...keep posting I am sure that the info is out there!
Mudslinger2
Old 02-19-2011, 09:20 PM
JakeROFL's Avatar
Thumbs up
Good call Mudslinger. I just bought a 2006-2009 Wolverine 450 repair manual on ebay. Once I get the CD in the mail, Im going to find this damn problem. Once I find the problem, I will update everybody. I see this is a major problem with these bikes.
Old 04-03-2015, 07:23 PM
Murdock303's Avatar
Default Same problem
Hi did you ever figure it out?
Old 04-04-2015, 01:11 PM
greg74's Avatar
He probably sold it, that was over 4 years ago.
Old 04-05-2015, 01:19 PM
HCWHunter's Avatar
Default Post Fixes when you find them
It would be nice if folks remembered to post their fixes when they finally figured out a problem they have posted. Help out the community and make the search function more valuable.
HW
Old 09-11-2016, 07:39 PM
Stimsonizer's Avatar
So my 2007 Wolverine overheating dummy light is coming on, does anyone have any ideas where the place to start looking for my problem?
Old 04-28-2021, 03:17 PM
Scubasteve98's Avatar
If you checked all the temp sensors (thermostat, radiator sensor, and the one on the top of the cylinder) and they all have power going to them, then you have air pockets in your radiator. My fan wasn’t coming on at all and it was overheating I used a vac made for radiators to suck all the air out. Now the 2008 wolverine 450 doesn’t over heat and the fan comes on! AIR POCKETS PEOPLE. I searched so much for this my atv wasn’t running for weeks and I finally figured it out ! Hope this helps
HCWHunter (04-28-2021)
suzuki230
07-08-2016 10:03 AM
Nelson
06-22-2015 03:51 AM
Nelson
06-20-2015 01:59 PM
ragewraps
05-27-2015 08:07 AM
holmbergm97
05-27-2015 07:23 AM
Quick Reply: Wolverine Overheating......confused!
