removing front gear case
Old 02-22-2011, 11:39 PM
Polaris500Sportsman's Avatar
Question removing front gear case
Does anyone know how to remove the front gearcase on a 2006 Sportsman 500, or have a link on how to do it? Thanks
Old 02-23-2011, 01:02 AM
kcaves's Avatar
jack up the front end, make sure u don't block the bolts on the bottom of the frame that hold the diff in. take off the tires, remove the front axles, theres a roll pin in the front yoke that keeps ur driveline on the front diff remove that, slide the diff backwards and take it out, disconnect the connector for ur awd switch under that cover below ur headlight pod, take out the four bolts that hold the diff on and remove the diff
Old 02-23-2011, 11:50 AM
So I don't have to remove the A-arms or the hubs?
Old 02-23-2011, 07:48 PM
Kerbbirds's Avatar
have to remove the hubs to get axles out sounds like you need a manual
txkevin
09-21-2015 02:02 PM
Dabears1983
06-16-2015 12:17 PM
hoopduerr
06-02-2015 09:01 AM
cornermike
05-27-2015 10:04 PM
Biggieshortie89
05-26-2015 08:01 AM
Quick Reply: removing front gear case
