Polaris/AMSOIL Fluid Guide for Sportsman XP
Old 03-16-2011, 08:44 PM
cyberhedz's Avatar
Exclamation Polaris/AMSOIL Fluid Guide for Sportsman XP
I just wanted to create a separate post for my spreadsheet, perhaps get it stickied. Attached is a build of all the OEM and AMSOIL fluids as well as time intervals to change them, I built it for my 850, so the quantities are for that engine. This sheet should cover all of the new Sportsman XP's.
Old 03-17-2011, 04:37 AM
stendori's Avatar
I'm watching you!
looks like it does not work!
Old 03-17-2011, 04:56 AM
SeniorCitizen's Avatar
File unzips with no problem
File extension is .XLSX
Won't open
Renamed to .XLS
Still won't open
What was this created with ??
Or saved as ??
Old 03-17-2011, 05:20 AM
Here's the problem - at least my problem -
Pasted from elsewhere :
You got an XLSX file that was created using Microsoft Office 2007 but unfortunately you cannot open it because you have an older version of Microsoft Office installed on your computer that can only handle XLS files and not XLSX files.
Old 03-17-2011, 07:58 AM
TLC's Avatar
TLC
TLC is offline
Says you need to buy Office 2010. Would be just easier if you copy and paste the whole thing so people can just read it.
I cant, open it and I have a 3 month old Intel i7 quad core computer with 64 bit Windows 7.
I,m sure Amsoil 10w-40 is in there, thats close enought to OEM 2w-50 for most people.
Old 03-17-2011, 09:17 AM
bentarrow's Avatar
First Things First!
I went back a second time after reading it then seeing posts where no one could get in and on the second and third try an error code came up. Strange it came up fine the first try.
Old 03-17-2011, 09:28 AM
cyberhedz's Avatar
Here is a 97-03 excel version for those of you that arent using Microsoft office 2010, or the conversion filters (which are free).
Old 03-17-2011, 10:38 AM
Spdecat's Avatar
Do the new Xp's require all that service being done at 50 hours ? On my 08 most of the 50 hour service is done at 100 and 200 plus hours . No way could I do that every 50 hours some times thats less than a weeks riding . Like your changing the brake fluid and antifreeze every 50 hours ? more like every 2 or 3 years .
Old 03-17-2011, 10:57 AM
cyberhedz's Avatar
Yes, I think its all 20/100 instead of 10/50 now, I just forgot to update the sheet.
Old 03-17-2011, 11:14 AM
TLC's Avatar
TLC
TLC is offline
Only the motor oil is 50hrs.
Quick Reply: Polaris/AMSOIL Fluid Guide for Sportsman XP
