1998 Polaris Explorer 400 Charging Problem
Old 05-09-2011, 06:25 PM
john luttrell's Avatar
Default 1998 Polaris Explorer 400 Charging Problem
We all went our for a few hours this weekend and on the way back we noticed that the tail light on my brother's 400 explorer, was very dim. When we got to the house, it wouldn't crank with the starter, so I checked the battery voltage and found it to be just over 9 volts static. I then pull started it and checked the voltage with the engine running at 3000 rpm's and it stayed at just over 9 volts; I also should mention that the battery is less than a week old and the cables are good.
I checked all the connections and grounds and found them to all be good; I then checked for battery voltage at the red wire on the voltage regulator and it did have battery voltage at the regulator/rectifier, so we have continuity between the battery and regulator/rectifier. I guess I'll have him go get a new voltage regulator/rectifier, but I'd like to pick you guy's brains and see if there isn't something else I'm missing before digging in his wallet. Thanks in advance.....
Old 05-09-2011, 06:32 PM
SOUNDS like you found the problem! If has power in on the red wire,but not charging its the reg/rectifier, IF all other wires are plugged in and have good contact. OPT
Old 05-09-2011, 06:45 PM
Thanks OPT, I was hoping I hadn't missed anything.
Old 05-10-2011, 01:37 AM
mrtwostroke's Avatar
the only oops I have had with this sort of thing. Is putting a four magnet flywheel on a bike that needs a six magnet one. you can check for voltage going into the regulator. I think i had 16-18 volts something like that.
Old 05-10-2011, 08:12 AM
Yes, I have read where some folks have done that; this one has the stock flywheel on it.
Old 05-12-2011, 09:58 AM
trbojet1's Avatar
I have an 1999 Xplorer 400. I tried to use a 4 magnet flywheel. It would not charge the system with a 4 magnet flywheel. As soon as I switched it back to a 6 magnet flywheel the system worked fine. Hope this helps.
Old 05-19-2011, 05:54 PM
Update: I finally found the time to put a new rectifier/regulator in and the ATV charges like new! Thanks for allowing me to pick your brains.
Old 05-19-2011, 10:25 PM
Glad you got it fixed, now go ride it! OPT
txkevin
09-21-2015 02:02 PM
bikedad3
06-29-2015 08:58 AM
clsharky
06-08-2015 11:38 AM
Burrlok
09-24-2000 12:09 AM
blackmagic
02-26-2000 09:27 AM
Quick Reply: 1998 Polaris Explorer 400 Charging Problem
