2001 kodiak rear brakes
Old 05-17-2011, 08:13 PM
atldirtybird's Avatar
Default 2001 kodiak rear brakes
have a 2001 kodiak 4x4 front brakes work fine but rear brakes are not even getting any fluid to them took line apart pumped brakes and nothing any help? thanks in advance
Old 05-18-2011, 09:45 AM
Rear master cylinder?
Old 05-18-2011, 03:59 PM
Mud Slinger's Avatar
450 w/ independent suspension? My 04 400 SRA had a drum that worked on a cable without a master cylinder?
Old 05-18-2011, 04:24 PM
No independent suspension thanks
Old 05-18-2011, 07:57 PM
If it is a straight axle I would assume it is a drum brake and not a disc brake? My 400 had a drum on the left end of the axle. I had a lot of trouble with the seal and getting water in the drum. I ended up just learning to depend on the front brakes. I could tear it apart, clean the drum and shoes, and adjust it and the rears would work until I hit another good water hole. Do you have disc brakes on the rear or a drum? Are we talking about a kodiak 400 or a 450 (not sure it was even built in 01)?
Old 05-19-2011, 12:43 AM
thanks mud slinger it has disc brakes and is a 400 4x4 if that helps
greg74
09-10-2019 03:03 PM
Sandman2.0
07-21-2015 09:03 AM
timster911
07-13-2015 01:57 PM
RedRancher
07-10-2015 06:36 PM
Quick Reply: 2001 kodiak rear brakes
