polaris brake fluid
Old 06-04-2011, 03:59 PM
DOC HOLIDAY's Avatar
Default polaris brake fluid
hello,my brake fluid is low on my 2007 polaris 500,can i use dot 3 brake fluid from autoparts store or must i use only polaris brake fluid.
Old 06-04-2011, 04:52 PM
Jmuddin284's Avatar
unless you have a leak somewhere you might want to take a look at your brake pads. If they're not worn to where they need to be replaced then you can use pretty much any Dot3 or the dot3 and Dot4 compatible. I use advanced auto's brand and I haven't had any problems with it at all. For most (maybe all??) of polaris's fluids there is a less expensive alternative that will substitute for their brand and will work just as well with a little less pain in the wallet.
Old 06-04-2011, 05:00 PM
Just upgrade to any brand dot 4,better on seals than dot 3,as mentioned will mix with existing fluid,BUT best to flush system. I never used dot 3 after dot 4 came out. OPT
Old 06-04-2011, 07:19 PM
thanks,i will get some dot4 at advance.
Old 06-05-2011, 04:56 AM
stendori's Avatar
I'm watching you!
better off not mixing if if you can. i think polaris used dot 4 didn't they opt?
Old 06-05-2011, 05:33 AM
Early machines used dot 3,but dot 4 is compatible and can mix with dot 3,BUT I always flushed systems especially when doing brake jobs and used Dot 4. Dot 5 is silicone based and CAN'T be mixed OR used in systems calling for dot 3 or 4\(will eat the lines up). Dot 5.1 is the newest fluid,but is glycol based not silicone based like dot 5!! Dot 5.1 just has a higher boiling point than dot 3 or 4,BUT can be used in place of either!! Confusing I know,but we had to contend with this at the shop along with MINERAL oil recommended on KTM hydraulic clutch systems! My opinion just stay with Dot4. Dot4.1 costs more and only recommended for racing or high heat applications. OPT
Old 06-05-2011, 08:58 AM
On last line meant to say Dot5.1 NOT Dot 4.1!!! I still get confused over this too! OPT
Old 06-06-2011, 01:07 PM
HB AFTERMARKET's Avatar
HB AFTERMARKET
Check out our basic descriptions on brake fluids at Home - Hayes Accessories under products brake fluid.
Old 06-06-2011, 02:22 PM
bigcam400's Avatar
dot 3 or 4 be fine,..that sillycon 5.1 adsorbs water easy an give a real spongy peddle even when new,....dot 5.1 was designed for restored cars thats not drivein often....an confusing it is!
Reactant
03-30-2022 02:08 AM
toonces
10-16-2019 12:11 PM
Sandman2.0
07-21-2015 09:03 AM
sublime250
07-11-2015 11:52 AM
rcappie4
07-10-2015 04:54 PM
Quick Reply: polaris brake fluid
