engine vibration
Old 06-17-2011, 10:13 AM
xAtvRiderx's Avatar
Default engine vibration
Just bought a new 2011 grizzly 450 love it, but i notice there is alot of engine vibration even when reving....Seems to tire my hands after a little ride. I sure hope this is not normal. It is a bit much. Why is there so much vibration hope this goes away after breakin time...
Old 06-19-2011, 12:37 PM
xAtvRiderx's Avatar
Default Unsure
Thinking on trading my 450 in on a rancher at. This grizzly just has to much handlebar vibration and kills my hands on a small ride.I think i miss shifting so i can control engine rpm.. Oops let u know what happens
Old 06-19-2011, 01:18 PM
mudslinger2's Avatar
I haven't been stuck since the last time!
Default Huh?
Have you talked to your dealer about the vibration? Did you ride the quad before you bought it? There may be something not right with it if it is as bad as you make it seem!
Old 06-20-2011, 12:47 AM
Butch450's Avatar
If you just bought the thing let the dealer check it out. I have an 07 so no eps and a ton of work on mine and there is no vibration like your stating, at least not that I can feel in the bars.
Old 06-20-2011, 07:29 AM
TLC's Avatar
TLC
TLC is offline
When you swich from a IRS (Independent Rear Suspension) Grizzly to a SRA (Straight Rear Axle) Rancher you will just switch the vibratiion from the bars to your a$s. LOL
The 450 Grizzly is more of a competitor to the 500 Foreman than the 420 Rancher. the Rancher has less power,smaller 24" tires, rear drum brakes,no low range and no AWD diff lock.
Sure seems to be one heck of a down grade for buzzy handle bars.
Old 06-20-2011, 02:08 PM
ryder133's Avatar
Engines vibrate...
Old 06-23-2011, 12:10 PM
xAtvRiderx's Avatar
someone told me to have the dealer check the to make sure the crank is balanced. That is a normal thing with the 421cc liquid cooled engines. Anybody back me up on this? Before i ask the dealer about it and look like a idiot..
Old 06-23-2011, 07:20 PM
Butch450's Avatar
Do you see the bars actually shaking when you have it running? Being an 2011 not sure if you have the eps or not but it could be possible there is an issue with it. I would just take it in and find out if it's normal cause without doing that no one will be able to help you much. There could be something wrong or it could be your just not used to it. I know I changed out my grips to rogues and they are real comfortable. I can also ride 100 miles beating the hell out of it riding real aggressive on rocky trails without eps and not have my hands hurt or be tired from it. What were your riding before?
Old 06-24-2011, 08:48 AM
xAtvRiderx's Avatar
My dealer says its normal. I just need to get use to it. My last bike was 15 years old.
Old 06-26-2011, 08:43 PM
CraZySteve's Avatar
The 421cc engine does vibrate a little more than other Yamaha engines for some reason....
If you are that worried about feeling the vibration in your handlebars - just go out and by a RoxSpeed FX anti-vibration handle bar riser
ROX Speed FX Elite Anti-Vibration Risers - DennisKirk.com
I bought one - not because of the vibration - because I used it on my sled and it ROCKED! So now it is on my quad - I get a 2" rise and the benefit of anti-vibration again not due to engine but the rocks etc that I hit.
Quick Reply: engine vibration
