new to me 89 Yamaha Pro-Hauler 250; No Spark, Need Help
Old 09-19-2011, 04:18 AM
85quadracer250's Avatar
Default new to me 89 Yamaha Pro-Hauler 250; No Spark, Need Help
Hi Everyone,
this is my first forum post here
I have recently bought this neat old 1989 yamaha Pro-Hauler atv for a few hundred bucks, non running.
Ive got quite a few bikes and quads and fix them up and ride as a hobby so this isnt completely new to me or my friends.
It was made very clear to me before i bought it that it was not running and has no spark.
I was told by the previous owner that he was told by the man he bought it from that he thought it was a bad cdi (he never had it running either),
I did a quick ohm check of the stator and personally i think the stator is bad.
Ive charged up the batt and cranked it over and confirmed no spark, I think everything is connected correctly, Main fuse is not blown.
I need some help...
Does anyone have a service manual for this bike or an equivalent?; scans or info from the electrical troubleshooting section of the manual would be a huge help.
Is the motor the same as a bear tracker or timber wolf?
Can any one give me any idea on what range of ohm values one should expect to see on this stator, mainly the trigger coil?.
I think it should be 200-330 ohms (educated guess based on treads about other yamahas) and I believe when i checked it quickly with an auto ranging meter is was more in the range of 22,000 - 26,000 Ohms which made me think it prob wasn't the CDI but instead a bad trigger coil but obviously I need to do more testing
Any help or conversation would be appreciated
Corey
Old 11-25-2011, 05:59 PM
gar2y's Avatar
Default Prohauler CDI
I had the same problem about 12 years and definitely it was the CDI at a cost (parts only) more than $300. I reluctantly ordered the CDI since my machine was virtually new with very little usage however, that corrected the problem and it ran good for maybe 25 hours over the next year then failed again. The ATV has been sitting behind the shed ever since. I was told at the Yamaha service shop that this is typical for the machine. I could not further justify investing $$ for such short life expectancy. The part sales now closer to $500.
Old 09-11-2015, 07:36 AM
petes's Avatar
Default 1989 pro hauler
hi ive got a 89 pro hauler runs great got everything but cant find a seat for it any where can some one point me in right direction
Old 09-12-2015, 03:11 AM
If you have the seat frame, a good upholsterer will be able to re-cover it, using new foam if needed. Check a local ATV or motorcycle dealer, they may know of someone near you who does it.
Chillibean
09-05-2020 04:02 AM
drewy2dope
Ask the Editor
11
07-31-2015 09:36 AM
ScopeZ_
07-28-2015 01:44 AM
Ty64
Technical and How-To Articles
07-25-2015 02:02 PM
07-07-2015 11:00 PM
Quick Reply: new to me 89 Yamaha Pro-Hauler 250; No Spark, Need Help
