Need Help!! Blater idles But when i push the throttle it dies!!
Old 10-19-2011, 11:16 PM
mxXXrider88's Avatar
Unhappy Need Help!! Blater idles But when i push the throttle it dies!!
I put a 2003 motor in my 1998 blaster. I grounded the extra green wire from the new motor and the quad starts right up but only idles. And when i disconnect the TOR box it shuts off too. I cleaned the carb, put in a new plug, and still nothing. Any kind of help would be greatly appreciated!!
Old 10-20-2011, 12:34 PM
JLsparky7's Avatar
The 2003+ model engines require you to splice the two wires on the TORS together. You cant just disconnect them.
Old 10-20-2011, 12:53 PM
but when i disconnect the wires it still shuts off..
Old 10-20-2011, 06:38 PM
Terrellster's Avatar
Yeah,.... it's not talking to the right circuit, so the CDI probably thinks it's got a short or an open that's not supposed to be there when in normal riding operation. The TORS system is a PITA when everything goes wrong.
As Stated above, if you're using the engine and CDI and all the correct electronics, you need to tie the 2 wires together, otherwise the CDI doesn't like it. Limits the Rev's or Kills it.
slowgsxr97
03-18-2022 03:40 AM
scram5050
07-27-2015 01:23 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
07-08-2015 02:16 PM
Robbbb55
07-08-2015 02:11 PM
MNatv89
07-07-2015 11:36 AM
Quick Reply: Need Help!! Blater idles But when i push the throttle it dies!!
