atv wont start!!! Help!
Old 02-29-2012, 11:44 PM
davethebrave's Avatar
Default atv wont start!!! Help!
My 366 wont start. I rode it a week ago, and i tried to crank it up a week later and now it wont start. i put a new battery in it and it will wont start. just cranks but wotn turn over. has gas, good spark, new spark plug, new oil and filter, clean air filter. help:?
Old 03-01-2012, 12:09 AM
bkwyoming's Avatar
Does it have valves? If so they may be to tight if everything else is ok. My sons quad did that. Couldn't hurt to look if it does. Standard rule, if it has spark and gas, its gonna run. If either is weak or not enough, it wont run. You said has gas, is there gas coming out of your float bowl??? Check your carb first then go check the valves. Too tight and they won't let enough gas in or exhaust out...
Old 03-01-2012, 12:25 AM
yeah the spark is definitely good and theres plenty of gas in the tank. theres in gas drainin from the bottom of the carb like if the float is stuck. its only been sittin for a week and it ran perfectly fine last week
Old 03-01-2012, 01:55 AM
95wolv's Avatar
I'm confused, you say it cranks but wont turn over? is the engine turning while you are trying to start, or does it just hang up and not keep turning with the starter? or do you mean it cranks but won't fire?
Gas draining from the carb is a bad sign, your needle and seat could be shot, flooding your engine, is the plug wet when you pull it to check spark? Have you done a compression check ?
Old 03-01-2012, 06:20 AM
sorry bout that. I posted on here pretty late and wasnt in the right mind set hahaha i meant turns but wont crank up.. it just turns endlessly as long as you hold the button, but wont start up. and its not leaking btw
Old 03-01-2012, 08:35 PM
Andy Bassham's Avatar
Another simple possibility is that the valve thingy under the float is stuck and its not getting gas. Had this on my 660 a few times a few years back. First two times I pulled it all apart to fix. After that, I unhooked the fuel line and shot a quick little blast (not much) up the fuel line into the carb with an air compressor and made it pop back unstuck. Much easier than taking it all apart no doubt. Quick fix... IF this was/is the problem.
Old 03-01-2012, 08:49 PM
yeah I was thinkin bout the carb too. Ive had it clog up before. And like i said it had only been sittin for a week and worked perfectly fine. Im gonna open the drain on the carb and blow air through it tomorrow mornin. Pray that tomorrow I have 3 working 4 wheelers instead of 2
Old 03-02-2012, 12:26 PM
alright well i took the spark plug out, put a little gas in it and put gas down the spark plug hole, and the engine cranked up for like 3 seconds than died. fuel issue?
Old 03-04-2012, 06:20 AM
Kerbbirds's Avatar
not gettin gas or maybe water in gas, , is there gas in the float bowl on carb?
Old 03-17-2012, 09:24 PM
Leroy7908's Avatar
Thank you all the same.
MikeyBoyesq
11-27-2020 02:44 PM
Mkp
03-28-2020 03:50 AM
tiresharkdbb
09-03-2017 02:06 AM
garyt1975
06-05-2015 08:53 AM
1000gade
05-27-2015 12:37 PM
Quick Reply: atv wont start!!! Help!
