Clutch removal brute force
Old 04-01-2012, 07:22 PM
fraiolib's Avatar
Default Clutch removal brute force
Was just trying to remove the primary clutch on a bruteforce 750, do not have the puller, with the snowmobiles it is possible to tip the sled on its side, remove the bolt, put water down in and insert the clutch bolt with teflon tape on it and it pops the clutch off, read online that some ppl have done this with the brute force but i had no luck, i know the right thing to do is buy the tool but wanted it off now, has anyone ever done this with water?
Old 04-25-2012, 10:16 PM
MrSummit's Avatar
I too have a sled and read the water thing but I don't understand how that works using the original bolt unless that bolt first threads thru the clutch and then threads into the crank.
And
Make sure to use the right puller. I about screwed up the thread on my crank by trying to use a snowmobile puller I had. The sled puller threaded in just fine and seated against the crank. I started to apply pressure, everything seemed normal, then I got the feeling it was turning a little easier. I removed the puller and the end of the puller was shiny on the sides a little. Uh oh, the puller had penetrated the crank bolt hole and rounded over the first few threads ever so slightly but enough that I had to use the bolt from my old clutch, oiled real well, and gradually work it in and back out a number of times and eventually was able to thread it all the way in.
BTW - I have a reverse thread tap that I bought for this but never used it so if anyone needs a $25 tap, let me know. Ha. I'd sell it for cheap because I'll never need it.
Old 04-25-2012, 10:42 PM
fraiolib's Avatar
The bolt on the sleds does thread threw the clutch and then the crank. On ski doos anyway.
Old 04-29-2012, 08:47 AM
MrSummit's Avatar
The bolt holding the primary clutch on my 2000 Kaw 400 4x4 does not thread thru the clutch then into the crank. The bolt goes right thru the clutch without hitting any threads, then threads into the crank. I know, I just checked (my OEM clutch is in a box because I replaced it with a Comet).
I do have a clutch puller that I will sell you. Used one time. The Comet uses a different puller.
Divergent12
12-30-2017 08:33 PM
velcro7279
08-24-2015 01:15 PM
Rollin23
08-13-2015 01:12 PM
toonces
08-05-2015 05:55 PM
ghost civic
07-15-2015 10:48 PM
Quick Reply: Clutch removal brute force
