04 honda rancher 400 shift problems
Old 11-24-2012, 09:56 AM
cbsurfbum's Avatar
Default 04 honda rancher 400 shift problems
Hey guys Im new here and i have been trying to solve this problem with my rancher. I Put a new clutch in it and now when i turn the key the ESP blinks 12 times . I tried resetting it but it just does it again. I have cleaned and inspected the angle sensor as well as the ECM they both look clean. The 4 wheeler will not stift AT ALL in Auto or ESP modes . It starts fine and engine sounds great I just cannot get it to shift into gear SOMEONE PLEASE HELP ME and tell me what i can do to find the problem . thanks !
Old 11-24-2012, 06:00 PM
papa hogg scoot's Avatar
May have to re-initalize the whole electric shift program..Sometimes when one or more component is removed from atv have to do this....If you dont have an manual you can search web or on here to find the method.....
Old 11-27-2012, 03:38 PM
cbsurfbum's Avatar
thanks for the Help I have tried to reinitialize the 4 wheeler but it still wont work. Now it is blinking 12 times ans will not shift into any gear. nor will auto work. I did swap the battery from my streetbike if that could mabye be the problem. Someone please help. I do not hear it even trying to shift. it just flashes ESP 12 times and repeats.
Old 11-27-2012, 08:16 PM
So is your atv battery hot?
Old 11-28-2012, 06:26 AM
cbsurfbum's Avatar
I will check the battery as soon as i get home. Im actually just going to but a new one from walmart just to rule that broblem out. I JUST WANNA RIDE LOL . thanks guys for all the help ill let you know if that fixes the problem.
Old 12-04-2012, 04:47 PM
cbsurfbum's Avatar
Ok guys I needs your help , swapped the battery still no luck. I attempted to reset and clear the code . nothing i just blinks ESP 12 times . I do not hear any noise coming from the motor. anyone have any ideas?
Old 12-04-2012, 05:21 PM
NASCARBO24's Avatar
Could be the shift motor control, thats common
Old 12-04-2012, 05:23 PM
NASCARBO24's Avatar
Another thing, if you cant hear it shift, could also be angle sensor
Old 12-29-2012, 06:14 PM
Rancher117's Avatar
Default Try this
I am not sure of the technical term is for some of this, but here goes. In the front of the bike, under the plastic fender and right in front of the steering forks/column (so to speak), there are 4 major wiring harness connections that are zip-tied to a fixed point. Take the off, unplug them, and clean them. What I did was carefully unplug each of them, (disconnect the battery) blew compressed air inside both ends of each connector making sure it is dry. Then I bought some dielectric grease ($10.00 a tube) and put a good amount (like tooth paste on your toothbrush) inside one end. Snapped them together and rode like it was new. No shift problems or blinking on the dash. Don’t forget to zip-tie the connections back to the original location. Everything pointed me to the “angle sensor” too but it was fine.
hugemoth
07-20-2020 03:28 AM
toonces
10-16-2019 12:11 PM
neilbedwell
11-10-2018 11:02 AM
ROWALKER
06-15-2015 05:38 PM
Dpearson03
Utility ATVs
05-29-2015 04:51 AM
Quick Reply: 04 honda rancher 400 shift problems
