250R Mix
Old 10-02-1999, 02:57 PM
TrxR's Avatar
I have a 1987 Honda 250R which is stock and I was wondering what I should be mixing my gas at??
Old 10-02-1999, 10:24 PM
Tim250R's Avatar
I use Honda Racing premix which is recommended 32:1. That is pretty much the standard mixture as far as pre mix goes.
Tim Thibodaux
1986 Fourtax 250R
Old 10-03-1999, 04:29 AM
JRM's Avatar
JRM
JRM is offline
Yep, 31:1 is perfect.. I have seen a few older honda's come jetted for 20:1 though, you should have light smoke and a dark tan plug..Joe
Old 10-04-1999, 01:49 AM
kevhog's Avatar
I always run 32:1 to 36:1, and have had no problems yet.
Old 10-08-1999, 05:33 PM
trx430ex's Avatar
Same as above.
Old 10-09-1999, 01:42 PM
RidE's Avatar
I've only had mine for almost 2 weeks, but I'll tell you anyways. After reading the manual, the 20:1 seemed really rich, so I've been riding everyday at 32:1.
Looks as if the best gas/oil mixture is 31:1-36:1.
- 1986 Honda TRX250R, 1996 Kawasaki Mojave, 1998 Kawasaki Mojave, http://www.geocities.com/MotorCity/B...8090/home.html
Old 10-09-1999, 02:24 PM
JRM's Avatar
JRM
JRM is offline
The less oil you put in the richer it gets... add more oil and you lean it out. Seems crazy dosent it? that is what the 2 stroke tech class I took told me. Think of it like this, oil is thicker than gas, add more oil (say 11:1 and it cannot get threw the jet's in the carb as fast as 32:1 does and in affect leans out your jetting! Now say 100:1 would be super rich, but since there inst much oil in that ratio,, it will not lube the engine more just because it is running rich. I Jet everything I own at 32:1 but my friend loves running his CR500 at 16:1 because he has it jetted perfectly for it. Nice tan plug, gobs of power since OIL burns hotter than gas and never wears out a ring or piston. He also gets better mileage. Hope I explained myself clear enough. I beleve MR.Know it all in dirtbike mag also said this years ago..
Joe
Old 10-11-1999, 08:00 PM
mikeb's Avatar
I run my TRX 250R at 40:1 with super M and 101 octian it really kicks ***.The oils now days are really alot better then they used to be you don't need to run 20:1 or even 32:1. I've racing like that for years and even with the higher octian I haven't smoked a motor.
Old 10-12-1999, 04:40 AM
JRM's Avatar
JRM
JRM is offline
I agree, my 2 stroke class instructor uses 32:1 but also says 40:1 is great for 250cc plus size engines as they dont rev to the moon like a CR80 or 125 does. Personly 40:1 is great, but personly i would not go any leaner than 50:1.. I often joke with my friend and his 16:1 mix, fill her up with a quart of gas and a gallon of oil..
Alex Rodak
09-13-2015 12:30 AM
Alex Rodak
09-12-2015 09:39 AM
Alex Rodak
09-11-2015 11:42 PM
Traci Carnahan Simmons
08-09-2015 03:00 PM
CRamshaw777
07-18-2015 05:46 PM
Quick Reply: 250R Mix
