Motor dies when put in reverse unless I hit Override button
When I Shift into reverse the motor dies unless I hold in the override button in. Anybody know what the problem is and how I can fix. I also need to replace the rear axle. Anybody know the price of one from Polaris. Both of these Problems are on my 95 Sportsman 400
Oh yeah can anybody give me tips on how big a tire will go on these w/ factory wheels w/o any lift.
Make sure that your idle is set properly....when you shift into reverse, your "short" for the override button has already taken place. If your idle is not set properly, you are just "adding" to the short.
I hope this works!!.....also, a srock axle is $250-$280, depending on the vendor. I would also go with a Durablue axle. It is a little more money, but a whole lot more dependable!
My MX 400 Sport
My MX 400 Sport
KimSJoh
14
07-18-2015 07:20 PM
