Mix ratio for blaster
Old 01-22-2002, 12:55 AM
SR2's Avatar
SR2
SR2 is offline
I just got a 94 blaster and everyone tells me to mix my own gas. Well whats the correct ratio and what octane gas should i run. Also whats the best oil to use? thanks in advance.
Old 01-22-2002, 01:05 AM
raktrakr's Avatar
a mechanic told me that 28:1 should do the trick,and that the banshee ran 32:1.anywhere in that range shouldnt hurt.i ran yamaha oil in mine
Old 01-22-2002, 01:43 AM
Blastermaster's Avatar
i run mine at 32:1 with klotz techniplate
Old 01-22-2002, 01:09 PM
tom18801's Avatar
i run 50:1 in everything i own and i use any oil that has specific mix ratios not anything that says will match all applications or anything along that line
Old 01-23-2002, 02:01 PM
timewass's Avatar
32:1 klotz techniplate (smells great too!)
Old 01-23-2002, 03:47 PM
Motordude0616's Avatar
32:1 Klotz Be-nol
Old 01-24-2002, 02:04 PM
SR2's Avatar
SR2
SR2 is offline
I think im going to go for a 32-1 mix. What else do i have to do to mix my own oil, like how do i shut off the stock injection and whats a klotz techniplate and whats the purpose? Sorry so many Qs but this is my first quad, and thanks for all the great responses.
Old 01-24-2002, 02:17 PM
Raptoryfn660r's Avatar
RIP Dear Friend
What year did the blaster add the oil injection system? My nephews 98 blaster and the blasters I have seen in the past all have the small oil tank on the left hand side in the rear and is added too under the seat. I am going to assume that the (SR2)
blaster in question has had the injection system removed if you were to run the correct 32 to 1 mix.
Chet
Old 01-24-2002, 02:19 PM
RIP Dear Friend
SR2,
Why would you want to remove the injection system and what advantage is there to gain?
Chet
Old 01-24-2002, 02:52 PM
timewass's Avatar
I removed the oil injection system from my Blaster for fear of it not working properly. I would just rather mix my oil:gas because then I know what it's running. You can buy an Oil Injection Block Off kit from a lot of manufacturers. I just removed the gear inside and all the other things with the injector. You also need to plug up the line going to your carb or you will create a lean mixture. Oh... a Klotz Techniplate is a kind of oil. Klotz (www.klotz.com) is the manufacturer and Techniplate is the type. The advantages would be that you know there is oil in your fuel mixture and a small weight loss.
Quick Reply: Mix ratio for blaster
