LT500R power valve
Old 03-12-2002, 07:58 PM
4x4rocket's Avatar
I have a 1987 LT 500r and was wondering how much the power valve should rotate on its axis? 5°,45°, 90°? I know that at 4500rpm the power-valve should rotate seen though the sight glass on the jug. I have seen virtually no movement. The quad is not sluggish just a little raspy at the top end. This leads me to believe that the power valve has little effect on performance. It doesn’t make sense to me. I would think it would run like crap. Any comments are appreciated. Thanks
Old 03-13-2002, 11:18 AM
Duneaddict's Avatar
4X, The mechanism will rotate approx 90 Degrees when it does actuate... I don't remember the actual RPM, but I know it's up there (about 5,500 RPM I think).
There is an extensive explaination of the different power valve configurations here:
http://www.offroadhaven.com/powervalve.htm
The LT500 uses the SAEC setup. You may be in need of adjustment if yours isn't working.
They do have a tendancy to gum up if you're not using a really good quality oil.
This may require disassembly and a good cleaning to make it work the way it should.
Hope this helps.
Old 03-13-2002, 07:00 PM
stormnorm's Avatar
I've had to replace the power valve governor assembly on my 87 zilla. The shaft had broken and the ***** were scatered. Also had to replace the thin spring on the other side of the jug.
87 Zilla
87 QuadSport
Cole Hadden
08-24-2020 11:11 PM
Hankey Pankey
07-31-2015 05:50 PM
Mojave250A
Ask the Editor
07-12-2015 09:10 PM
Unzzy66
07-11-2015 10:01 PM
Mojave250A
07-11-2015 10:38 AM
Quick Reply: LT500R power valve
