valve adjustments
Old 08-31-2002, 04:04 PM
reconbasher's Avatar
my valves on my 250x has started to chatter a little and i was wondering what the proper clearance gap should be for the intake and exhaust vales.
Old 09-02-2002, 09:47 PM
midlifecrisis's Avatar
just because they chatter doesnt mean they need to be adjusted.
my 400ex was quit I took it too the dealer too have the 30 hour service,,(valve adjusted). when i picked it up and started it the valves chattered .I asked the mechanic and he said thats normal , they where way too tight before,, he said i had no clearance at all.. my buddy says most times if they stop chattering then start worrying,
pick up a sevice manual and check them your self, thats what im going too start doing, its supposed too be pretty easy.
Old 09-03-2002, 01:34 AM
KNOWSALOT's Avatar
The Facility
midlifecrisis is correct. There is a small ammount of clatter to be expected from these engines.
Here are the clearances so that you see how far you are off. If you don't want to overdo it, set them at the highest ammount of clearance witin spec.
Be sure to check clearances with the engine cold.
Remove both rockerarm cover caps.
Remove the SMALL inspection cap on the right side of the engine and align the "T" mark on the flywheel with the notch in the inspection hole. See if you can move the rockerarms up and down. If not, turn the crankshaft one more time to the "T" mark. You want BOTH rockerarms to be able to move.
INT....0.004"-0.008"
EXH....0.004"-0.008"
Old 09-03-2002, 01:37 AM
KNOWSALOT's Avatar
The Facility
reconbasher,
By the way.....You didn't break anything on your quad after that close call did you?? I didn't see anyone hitting that jump as fast as you were.
I heard a "Ohhhhhhhhhh Shiiiiiiii" from everyone there at one time and when I looked up....all I saw was a 250X coming in for a grab bar landing...LOL
Glad you're okay though.
Old 09-09-2002, 09:37 PM
knowsalot,
naw i didnt but i thought i blew the rear shock but i didnt, It was just that bad wore out anyway.....while i was at trace state park riding yeasterday i did manage to warp my rear brake rotor.
fordfaithful21
12-07-2015 05:52 PM
Steeldon
Utility ATVs
09-05-2015 09:38 PM
Brandon400
09-05-2015 08:44 PM
Jason Richards
09-04-2015 06:17 PM
Hankey Pankey
08-17-2015 05:01 PM
Quick Reply: valve adjustments
